No. Because you will need space for substantial sinks. The orientation of the Mosfets isn't for heatsinks.
Look at the proper pcb
Also read that thread from start.
Ryssen said:
I will,jsut trying to avoid taxes and custom.Will wait till tomorrow and see.
Edit:If I order 80pcb´s from pcbcart the unit price is $ 1.71 + shipping and stuff,will calculate tomorrow.(allmost to god to be true.
Dang, that is a good price. If they turn out well I will try them for the second batch of Diamante boards.
This is what the price is when all fees (toolingcost) and stuff are addd:4,12$I calulated the price with toolingcost, shipping and taxes to me,and it ads up to 4,12$/pcb
And the price might vary some depending on the exchanges coarse.
Salas,arent you skilled to fix the Eagle files?
I do p2p. Because mainly I do minimalistic tube or FET prototype stuff. Sometimes I had transferred to a home etching board from a picture. Never had anything to do with board software.
But from what I saw from Crt's boards, his pdf worked very nicely. Do the China guys refuse to work from it?
This is what it says on their site:
"what file format do you accept?
Prefered RS-274X gerber format. But we also accept PCB files format like: Protel, Eagle, PADS"
Can crt do it?
Sent a qoute to Cogra today on 140 boards,hope to hear from them on monday.
And hopefully massimo gets a qoute to,then will have a little to choose from..
Can crt do it?
Sounds fine,can you make 2 more mounting holes for the PSU?i'm also thinking if we can have the board with scoring line in between the b1 and the regulator.. so anyone can use the regulator by itself.
xaudiox said:i can try redo the layout in protel.. i'm also thinking if we can have the board with scoring line in between the b1 and the regulator.. so anyone can use the regulator by itself.
I am working on a layout with that thought in mind. It will have the outputs at a better spot than they are now. Also more decoupling on the power lines and an integrated stereo volume potentiometer. But it will take time to finish it.
- Group Buys
- GB for DC coupled B1 buffer with shunt PSUs
