specialidiot said:
Could you point me to the F5 article?
Thank you very much.
Note that there are still two pairs of Conrad heat sinks left on ebay.
You can find it on www.firstwatt.com
cviller said:
can you be a little more specific?
max426 said:
Thanks Jim. Even though I've been navigating the www since Al Gore was poopin' yellow, I couldn't find that article. Why it isn't in DIY is beyond me.
Now it makes a lot more sense! Sorry for being cranky, I thought you were just lazy.
You should also read my guide ( you can find it on the F5 PCB WIKI )
merlin2069er said:hey.
anyone putting together a group buy for a chassis?
You mean something like this one?
Aelph 30 Stereo
Anthony
elecres said:hello ,thanks cviller boards looks nice.questions from newbee.what rectifier should i use with the power supply and where can i purchase them? thanks in advance!!!
It's in the article somewhere (http://www.firstwatt.com/downloads/F5-om_sm-080527.pdf) - I think it is should be rated for 30A or 25A and 250V. You can get them anywhere and they are called a diode bridge. Do a search on "diode bridge" on mouser and click rectifier something a couple of times and you'll end up with a couple of thousands to select from.
I can't really recommend any, just make sure you get one with the correct or above rating.
I have used these,
Mouser
844-GBPC3506A
844-GBPC3512A
Mainly because they don't cost too much
Dont forget BER142 Heatpads for these things.
Tea-Bag said:
I have used these,
Mouser
844-GBPC3506A
844-GBPC3512A
You use a heatpad on a bridge? Is there an advantage over
just using silicone paste? I'm not arguing I don't know just curious
I thought they needed to be isolated from chassis. Maybe not.
I't probably doesn't matter much. They don't put out as much heat as output transistors.
They are isolated internally from the package
Usually not. Single or dual diodes in to-220 or to-247 packages do however need isolation.
- Group Buys
- Gb: F5 Pcb
