anybody try these?
http://www.atlassound.com/products/partNumber.cfm?pn=FC104
AtlasSound.com - Products
money on the line-
http://www.atlassound.com/openLetter_AtlasSound.pdf
openLetter_AtlasSound.pdf (application/pdf Object)
money on the line-
21145
http://cgi.ebay.com/pair-10-Klangfi...0QQihZ002QQcategoryZ50597QQrdZ1QQcmdZViewItem
eBay: pair 10" Klangfilm KL-AZ415r AlNiCo speakers for RE604 (item 120126503820 end time Jun-08-07 19:00:00 PDT)
21332
21332
some history in here-
http://cgi.ebay.com/Konski-Krueger-...5QQihZ002QQcategoryZ50597QQrdZ1QQcmdZViewItem
eBay: Konski Krüger Klangfilm O7a fullrange fieldcoil Eurodyn (item 120126498175 end time Jun-08-07 19:00:00 PDT)
Description
12" Konski & Krüger O7a fullrange
http://klangfilm.free.fr/
[Karl Krüger] is also known as the executing company for Hans Eckmiller’s legendary coaxial driver type O15a, which also bears the "Konski & Krüger" sticker on the back and which was used by the German Reichsrundfunkgesellschaft RRG. Eckmiller was also the leading sound engineer for Klangfilm. It is likely that both companies cooperated. Karl Krüger was a technician of early Klangfilm prewar time. He design Klarton, Eurodyn, and other big speakers for Klangfilm. His last design was round speakerhorn used in late Klarton Alnico. Then he worked for Lorenz cinema and made very special amplfiers like Lorenz BN6 BA6 which had seperate power supply. After, he fonded his own factory Kronski & Krüger in Berlin which have been successful for some time in making cinema speaker for Berlin and surrouding. Then he was prisoner of war, then he worked for Eckmiller.
Technical data: Diameter 32cm (12"), voice coil 8,2 Ohms, field coil 2,0 KOhms. For the external excitation of the magnets DC voltage (220 V) is needed. Shipping costs worldwide incl. insurance costs 110 USD. They are very heavy speakers (more than 10 Kg)
Description
tomtt said:
isophons
fe208es
22317
22317
thick magnets
You had used to immediately before, but there was no problem in operation.
The center cap purchase at that time was dented with young child power.
Sucking out, it is to do as before but dent about of diameter 1cm remains in one side.
You do not use the solder.
It has not been taken to the photograph, but also the screw being attached, it increases.
Because it is cheap exhibition, we ask with junk item treatment.
might be old
http://cgi.ebay.com/Vintage-12-Spea...3QQihZ013QQcategoryZ50597QQrdZ1QQcmdZViewItem
without alot of friction?
http://cgi.ebay.com/VINTAGE-ALTEC-L...6QQihZ002QQcategoryZ50597QQrdZ1QQcmdZViewItem
212032
The cone moves pretty freely
I plugged it into my Showman & played a bass through it,
the speaker worked but rattled a bit on the low end.
212032
large phase plug
http://cgi.ebay.com/2x-Speaker-box-...ryZ50597QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/Zeiss-12-cinema...5QQihZ009QQcategoryZ50597QQrdZ1QQcmdZViewItem
23010
23010
altec 419-
panasonic-
23226
tomtt said:An externally hosted image should be here but it was not working when we last tested it.
that must be Eminence OEM
Klangfilm Kl L 205
rft
isophon
siemens
23559
rft
isophon
siemens
23559
bozak
trusonic
altec
philips
woofers from -
http://cgi.ebay.com/ws/eBayISAPI.dl...ndexURL=0&photoDisplayType=2#ebayphotohosting
23713
trusonic
altec
philips
woofers from -
23713
- Full Range
- full range pics-
