Also, have a look at this:
And note the distribution of the human voice. I think you'll agree that Leonard Cohen does not often hit the soprano range (whose fundamentals top out at ~ 1.5k), so I don't see how bringing in a tweeter above 10k should help much, though I don't doubt your experience with it.
Bob Reimer said:Please contact me if you want change or replace your drivers.
If Gringo decides to go this route, please call me, and I'll pop up to your place and grab them from you.
They will be in the scratch and dent bin and heavily discounted yes?
Cal
paulb said:I guess that's why RAW's kits all come with a tweeter.
I may be wrong here so correct me if I am. All of the kits that Al at RAW sells that utilize the CSS drivers AND a tweeter, are using the the WR versions...not FR version. He does in fact sell the FR version, as single driver fullrange kit.
I know my equipment here is far from "hifi" but those that have heard my little FR125s speakers have had nothing but great things to say about them. Usually, the comments center on the bottom end and the fact that the vocal range comes through so clean.
That's the fun thing about audio DIY is that there is no "perfect" approach, especially when you throw in the human factor. Hopefully they come around a bit for you and if not, have fun continuing the pursuit of audio bliss my friend.
Noidster
Here what I found so far with my FR125S pairs. Their temporary home is in a BR box of size about H:22in, W:18in, D:14in. I just recall this from memory. Could be off couple of inches.
1. They were quite plain sounding when first turned on but was good after about 40 hours of exercise.
2. They seems to me a set of fast speakers. In the current cab, they lose coherence if driven by high speed amps (Accuphase and my DIY current source output amp similar to Nelson's design). It seems to me the mid and high are faster than the low. I couldn't hear it for long. But if I use my Yamaha CA410 with cranked up bias and AudioInnovation tube amp, it sounds very good. I hear it for hours and keep going. I am planning to do more testings to understand why these amps makes such a big difference.
3. It peaks around 6.5KHz. Don't know if this matters.
MJK said:I have measured many drivers before and after break-in and not seen any significant shifts. Just curious for more data.
For the one set of broken in drivers i tested, the differences were less than my meaurement error (these drivers sat for a week unused before testing).
dave
Re: System is okay..I think
A true FR is a very daunting task...
dave
GringoAudio said:Is true full range the Holy Grail?
dave
I've had 20 tru here... here are the out of the box measures. I used FuzzMeasure & added mass.
Sorted by measured Cone Mass
Number Fs Re Qms Qes Qts Vas Cone mass Sd dB comp cm/dyne BL
2 73.03 6.80 3.5796 1.1593 0.8757 3.9782 4.2658 50.2655 83.3634 1.11E-06 3.3897
18 75.28 6.90 5.7200 0.9142 0.7882 3.5894 4.4496 50.2655 84.3435 1.00E-06 3.9871
4 74.08 6.80 5.0246 1.1376 0.9276 3.6618 4.5040 50.2655 83.2715 1.02E-06 3.5413
22 75.16 6.70 4.9142 0.9739 0.8128 3.5344 4.5332 50.2655 83.9810 9.89E-07 3.8391
21 75.20 6.80 5.1025 0.9024 0.7668 3.5241 4.5416 50.2655 84.3064 9.86E-07 4.0227
10 82.10 6.80 6.1270 0.9659 0.8344 2.8899 4.6465 50.2655 84.2932 8.09E-07 4.1094
19 75.38 6.90 5.6304 0.8744 0.7569 3.4215 4.6555 50.2655 84.3461 9.58E-07 4.1728
3 73.36 6.90 5.5569 1.0792 0.9037 3.5979 4.6744 50.2655 83.2967 1.01E-06 3.7129
14 74.53 7.00 5.3559 0.9346 0.7730 3.4796 4.6827 50.2655 83.9824 9.74E-07 4.0542
25 74.06 6.80 4.8264 0.9369 0.7846 3.4860 4.7337 50.2655 83.8972 9.76E-07 3.9999
13 77.28 7.00 5.6756 0.9485 0.8127 3.1914 4.7488 50.2655 84.0148 8.93E-07 4.1267
12 81.84 6.90 5.8948 0.9435 0.8133 2.7752 4.8693 50.2655 84.1779 7.77E-07 4.2808
1 70.99 6.80 5.1896 1.0767 0.8917 3.6398 4.9343 50.2655 82.9291 1.02E-06 3.7297
16 76.02 7.20 5.9826 0.9136 0.7925 3.1598 4.9565 50.2655 83.9203 8.84E-07 4.3211
24 71.07 6.70 4.7223 0.9440 0.7868 3.6017 4.9752 50.2655 83.4694 1.01E-06 3.9724
15 71.50 7.00 5.9231 0.8332 0.7306 3.5474 4.9908 50.2655 84.0242 9.93E-07 4.3417
23 75.29 6.70 4.2480 0.9296 0.7627 3.1936 4.9996 50.2655 83.7654 8.94E-07 4.1303
17 74.71 6.90 4.6597 0.8907 0.7478 3.1948 5.0756 50.2655 83.8519 8.94E-07 4.2978
11 77.10 7.00 5.9380 0.8794 0.7660 2.8199 5.3994 50.2655 83.7755 7.89E-07 4.5647
20 71.16 6.70 4.5718 0.9185 0.7648 3.1065 5.7538 50.2655 82.9624 8.69E-07 4.3336
Average from all 20
all 74.96 6.87 5.23 0.96 0.80 3.37 4.82 50.27 83.80 9.43E-07 4.05
all 14.8% 7.3% 48.7% 34.0% 24.5% 35.7% 30.9% 0.0% 1.7% 35.7% 29.0%
Ave less top2/bot2
75.16 6.87 5.30 0.96 0.81 3.37 4.78 50.27 83.85 9.43E-07 4.04
(max-min)/ave
14.8% 7.3% 48.0% 34.1% 24.4% 35.7% 31.1% 0.0% 1.7% 35.7% 29.1%
Average set eliminating mass outliers, then Fs outliers (a set of 12)
Ave less top2/bot2
74.71 6.89 5.24 0.95 0.80 3.42 4.76 50.27 83.89 9.56E-07 4.05
(max-min)/ave
7.7% 7.3% 33.1% 32.2% 24.7% 14.7% 12.0% 0.0% 1.3% 14.7% 19.8%
Average set eliminating mass outliers, then Fs outliers, then Qt outliers (a set of 8)
Ave less top2/bot2
75.37 6.89 5.22 0.93 0.78 3.37 4.73 50.27 84.03 9.44E-07 4.08
(max-min)/ave
4.3% 7.3% 33.2% 10.7% 7.1% 11.1% 9.9% 0.0% 0.7% 11.1% 11.8%
dave
Note: despite lining up in mono-space in my WP, it doesn't in my 2 main browsers... cutting and pasting and setting to a mono-space font (ie courier) should line it up into columns
Average from all 20
Ave less top2/bot2
(max-min)/ave
Ave less top2/bot2
(max-min)/ave
Ave less top2/bot2
(max-min)/ave
dave
planet10 said:Note: despite lining up in mono-space in my WP, it doesn't in my 2 main browsers... cutting and pasting and setting to a mono-space font (ie courier) should line it up into columns
Code:
Average from all 20
Ave less top2/bot2
(max-min)/ave
Ave less top2/bot2
(max-min)/ave
Ave less top2/bot2
(max-min)/ave
Did you get my reply emails Dave?
Well I have the FR125 in the mini Onken boxes. I've listened to them for a month now and think they are quite nice. They are detailed, clear and have a very nice sound stage. The speakers disappear when the music is playing. I'm using a digital Panasonic SA-XR50 reciever to power them. I know there seems to be a lot of accolades for the bass, but quite frankly I could not live without my Tempest sub integrated into this mix.
I just have to think of a finish scheme for my cabinets. Will post a pic when all done.
Vikash said:Did you get my reply emails Dave?
Yes... was busy all yesterday sorting thru the last 6 palletts of Monsoon bits that we cleared out of the North American serivice facility... anyone wants Monsoon bits this is the last dance...
I was thinking of the code tag but i was under the impression it had been disabled.
dave
Dave, I measured them all again today. I used 20g added mass this time instead of 4.5g and incidentally this made little difference to the VAS results. All the drivers consistently measured higher Fs by a few Hz which I'll attribute to the warmer climate in my testing area. Other than that I'm still getting different results to you, although they appear more consistent with that of npdang.
Code:
fs vas qts qms qes
a 66.614 5.726 0.683 4.594 0.802
b 65.457 5.995 0.752 5.863 0.863
c 66.839 6.026 0.686 5.289 0.788
d 63.480 6.003 0.699 5.339 0.805
avg 65.598 5.938 0.705 5.271 0.815
npdang 64.015 4.699 0.714 4.240 0.860
dave 75.370 3.370 0.780 5.220 0.930
Perhaps I missed it, but what drive level did everyone measure at? The higher the drive level, the lower the Fs/greater the Vas. We regularly measure our drivers at 1W (2V or 2.83V into 4 or 8 Ohms, respectively), that will result in pretty significant changes versus the typical 50 mV signal...
For example, one driver we build for another OEM measures out at 29 Hz with the Woofer Tester (50 mV), but when measured at 2V (1W), measures out at 24 Hz, basically on-spec.
Dan Wiggins
Adire Audio
Dan Wiggins
Adire Audio
DanWiggins said:Perhaps I missed it, but what drive level did everyone measure at? The higher the drive level, the lower the Fs/greater the Vas. We regularly measure our drivers at 1W (2V or 2.83V into 4 or 8 Ohms, respectively), that will result in pretty significant changes versus the typical 50 mV signal...
guess it is time to rejig my jig... i'm using the headphone out on my G4, certanly not 1 W....
dave
Dan:
Wow! Is there a standard drive level?
If 50mV is not standard, do you think it might be possible to apply a conversion factor to the 'Woofer Tester 2' results?
TIA ... /Dave
TIA ... /Dave
Vikash said:which leads to the next question, is the chosen box design still valid when used at higher power levels...
From my own tinkering and gleaning from audio forums, that's an issue.
If one wants to run their 500W HTiB flat-out, a bass reflex (incl. the Onken) would be a poor choice with most any driver.
But if you're like me and wanting to get the most out of a 3 watt SE triode amp, sealed enclosures will be a dissappointment.
I have a box design that lowers the resonant frequency of the system. It might also solve the problem throughout different power levels. But I have not tested at higher power levels yet. Got my fingers crossed.
- Full Range
- FR125S post break-in T/S parameters
