I have not seen reference to a foobar audio player thread for the purpose of learning the software and its plugins.
This thread can be a catch-all for foobar questions on the program, its skins, plugins and accessories.
I have just begun to seriously use foobar after letting it lay dormant for years thinking that a lot of programming skill would be needed to do the configuration.
Then I returned to it as a result of the discussion by single driver speaker builder Bob Brines in the single driver forum.
a link to that here: http://www.diyaudio.com/forums/full-range/121277-dsp-single-driver-speaker.html
Questions about foobar began to build up and so a better place to discuss this digital product is in the digital forum.
After this introduction I will try to keep the messages short and stick to how-to info only. These will be questions for individual answer.
Here goes....
Here goes....
The last reference to foobar was in 2006 or some time from the threads that got pulled up. Three years later many add-ons have been made and I decided that now was the time to learn the details of the program.
Foobar runs on many platforms. I use Windows XP but discussion of foobar can range into MAC and Linux as well. It is open source and free.
My first step was to download the software. It comes as a zip file in the 7zip format.
Get Foobar.
Get 7zip and use that to open the directory. So far this is pretty straightforward. Foobar has a rather plain interface but many options are available via a number of control keys. I beginning this myself so I know only a little of it.
Readers should be aware that help with foobar for new users assumes no prior knowledge.
When I got foobar my primary purpose was for streaming internet radio that could play Ogg files. The site I use has Ogg as a format streamed from ibiblio. Foobar started up when selected from the Windows menu asking to select a player. Even the base grey control window shows a graphic display of output.
Get Foobar.
Where to go to ask questions?
I'm making this thread because the answers to questions are more generally forthcoming in DIY audio rather than the older forums which have had foobar on since it's inception.
The primary foobar discussion is at Hydrogen Audio, a mature site which may provide answers in a technical vein requiring more extensive inquiry.
That is here:
Hydrogenaudio Forums -> foobar2000
This foobar thread is intended to be an introduction where new users can ask simple questions.
After getting foobar going, I wanted an Equalizer that can do balance shift like winamp. The next subject will be on VST (Virtual Studio Technology) installation of the Classic EQ plugin for foobar. VST is required by foobar to install these third party plugins.
The recommended VST "wrapper" is here:
foobar2000 3rd party components
This is the direct link from the previous discussion.
This once again a zip file to open (check for viruses) and install. My thanks to Anders and others who helped me get this far.
more next time.
That is here:
more next time.
Well, hopefully I'm following the right intention here...
I've been using Foobar on a WinXP Media Center computer for over a year. I usually listen to FLAC or WAV files.
I think one of my favorite features is the ability to set the equalizer and save different settings for different configurations. For instance, when I listen to amp "A" with speakers "B," I like my eq one way. If I listen to amp "A" with speakers "C," I might need a different eq setting. Foobar allows me to save different settings and then open whatever setting I need for the particular configuration I'm using.
Great thread Lon.
Mike
Great thread Lon.
Mike
some important checks to perform
copied from Ander's replies at full range forum:
Make sure that the vst wrapper is listed under components
http://www.superenkelt.se/images/components.jpg
Check that the vst wrapper is listed under active dsp
http://www.superenkelt.se/images/dsp.jpg
All other settings are configured via VST setup.
These two jpgs are very helpful.
At this point I have not used "rescan" at all.
My result from looking at the components tab gave George Yohngs' VST wrapper in the components tab.
My result in looking at the DSP tab is empty.
I have made the vst folder in Foobar and put the Classic EQ dll in there.
Am I ready to use the VST blue icon in the task bar to
1. Add that folder
2. Rescan
At this point I feel it is easy to do things out of sequence, or worse skip something.
Also I am really bad at using html highlights. But let's not get distracted.
I gave the key combination to open properties in Foobat incorrectly: it is control +p to open the window.
1. Add that folder
2. Rescan
Still don't know what I'm doing with this but I opened the DSP configure:
control +p > playback >DSP
and highlighted one of the effects in the right hand panel. I clicked on the <-
arrow to move it to the active DSP panel. Then I did a couple more.
Then I put them back by highlighting and using the -> button between the left and right panels.
Like I said, I don't know what I'm doing but "configure" at least allowed me access today.
I haven't done the rescan yet. (see previous post.)
I am exercising all this caution so as not to screw up the Foobar that is running so far.
not much happening
Today I fiddled with configure in VST setup:
Moved the George Yohng wrapper to active.
Moved 'Equalizer' ( not classic EQ)
Moved Crossfader
Also did the rescan for VST plugins folder. Only thing in vstplugins folder from my inspection of directories is Classic Eq. I don't see it in the VST configure right panel.
It all seems a bit opaque at this point.
I have two Equalisers that open to reveal the same thing.
Moved Crossfader
Progress
I have now seen how to "Use VST Effect" first item when right clicking the icon on the task bar called VST. This may seem overly wordy but using this is still complicated.
Progress is that Classic EQ is indeed under Use VST Effect. After looking it over I did not see immediately how to make "balance" adjustments and have to review what Anders said about that.
The goal is to have a big slider that gives discreet right and left channel audio for A/B comparisons. I have not seen this on the panel in Classic EQ.
crossfader
Trying to find a balance control I looked under the DSP option in Foobar-- not VST. Crossfader is in active DSP and selecting "Configure" opens the crossfader.
Crossfader is is not a balance control. I am familiar with using Fade In and Fade out with this audio editor:
GoldWave - Audio Editor, Recorder, Converter, Restoration, & Analysis Software
but in music streaming I do not see an application for Crossfade.
Editorial: doing DSP is surely like finding Usenet or the web for the first time. Trying to grab the dragon's tail only shows how much there is to control and so narrowing focus keeps the frustration level manageable.
more progress
The link button in Classic EQ gives control of left and right when turned off. Clicking on this gives no immediate screen feedback so using it at all took some time to locate and turn off.
Be careful using Output on these things. Jacking up Output will cause distortion and possible damage.
Classic EQ can give different levels using the Output. But there is still not a way to effectively do an A/B test.
Today I added George Yohng's Limiter which is packaged in with his VST wrapper.
Once I established one and only one vstplugin folder and did the rescan after addition, the limiter showed up in the sub menu for Use VST Plugin.
I have the routine down now but there are many things for Foobar enhancement that have yet to be explored.
For a long time (years) I have sought a software solution for real time normalization (stabilization) of audio-- what is called Midnight Theater in special modes for home theater components such as receivers.
Stabilization means raising the soft parts and limiting the loud parts during real time playback. I have only seen these things offered as hardware by Terk and before them Sima Electronics. Sima called their device a volume stabilizer. I have one but I was not getting a result after years of use which means the unit failed or was not getting the right kind of higher power input to operate.
Who knows of a plugin for Foobar that does volume stabilization during playback?
What you want is a dynamic compressor.
foo_dsp_vlevel - Hydrogenaudio Forums
SoNic_real_one,
Thanks for answering.
I just realized that Foobar having this is inconsequential. My bad.
The required dynamic compression is needed for files that play video such as saved tv shows and such.
I have made this inquiry at VLC which is the most likely to have open source updates. They do not have such a thing to my knowledge.
Well, on to other issues.
DSP controls a lot of things. My heretical question is: could DSP produce the EnABL effect discussed at length elsewhere. If Scott or Dave are lurking about this question might seem ignorant. I have EnABL'ed a few speakers. I just find this area of inquiry curious.
Plus I still haven't got that "balance" slider.
Foobar is my favorite piece of software, and you are doing god's work by spreading the word, my friend. But your second post is misleading...
Foobar runs natively only on Windows.Foobar runs on many platforms. I use Windows XP but discussion of foobar can range into MAC and Linux as well.
Free, yes; Open source, no.It is open source and free.
It's just a simple executable installer, no need to download 7-Zip.It comes as a zip file in the 7zip format.
qest,
All these things are good to know. I have been mistaken before and will be again. The how-to thread is just a place I ask questions in the
Audio DIY realm rather than Hydrogen.
I actually did think it was multiple platform from refs to installer files or tar files or something. Thanks for clearing up the error.
thanks solve,
I hope there will be more discussions about these things.
Specifically I don't know how to use the EQ to match driver output graphs.
Also there is this. I use single driver speakers in an unsymetrical manner
(shudder if you wish) with one BIB that is Fostex 127e with an EnABL job
and one MLTL designed by GM for the FE167e which was discussed some time ago. (I participate on the low end of the hobby and doing single builds keeps me in the game.)
Would it be asking too much to EQ each driver separately and then have output a bit greater on one side for my listening position? Since all these things are separate settings in Classic EQ it should be doable.
My source is the Parts Express DTA-1 t-amp from the AC'3 sound output of
my computer board.
The question for Foobar users with VST is where can the settings for EQ be found? Has anybody posted these things in the manner of:
band setting one at such and such
band setting two at another
and so on for each side separately?
my computer board.
Today I used the AiXAcoustics style EQ.
This is like the proverbial cow with a shotgun. But it will provide much fascination for those who want to use the drag- style band manipulator. The manual provides many clues as to how to use this sophisticated EQ.
I mention cows and shotguns because, though I can hear the changes dragging the dots does, I am not very good at detecting what needs to or should be used.
- Digital Line Level
- foobar audio player how-to thread
