FirstWatt J2
This is for noobs :
https://diyaudiostore.com/collections/aca-mini
It is not about the soldering, but the debugging in case of trouble.
Build something easy first, save your Semisouths for later projects.
My 2 cents,
Patrick
I regard myself as the biggest noob on DIYaudio, even if I already completed ACA F5, B1, B1 Triode, and almost there with F6, V-FET N-channel, and ACN. But I can’t keep completing ACAs over and over again.
So you are saying I should save my pair of semisouths for an F8? I must say, I am having impure thoughts about the F8 now that it is no longer in production.
Joined 2008
Just curious…I often have my head in the sand (so to speak).
I noticed that Reno HiFi mentioned on their webpage that the J2 is discontinued (I was looking at prices on some items being sold off before they close down for good).
I confirmed the available new column on First Watt page says “N”.
I wondered if there was an official announcement I missed?
I also wondered if Papa was going to release any official circuit into the wild?
mkc
Joined 2002
As tempting as the J2 is it requires a lot of parts that is hard to source. Where as the Aleph-J is somewhat easier although still requires some p-channels. This has made me pondering about an Aleph-J with F8 style input stage. Nelson, have you tried something like that? Perhaps named Aleph-J.5 :unsure:
mkc
Joined 2002
Hi Patrick,
I'm familiar with your efforts. I have bought the parts to try it out. However, my thought about the Aleph-J with F8-styile input stage was response to Nelsons comment about bringing something like the J2 to the Diyaudio store. Thinking that such a circuit perhaps would be easier to build. But, perhaps there might not be enough advantages in such a circuit, apart from using only 1 p-channel, compared to the standard Aleph-J. The p-channel can be had for reasonably price through the shop.
Mogens
Aleph-J is different from the J2 in the way the current source is modulated.
The J2 (and F8) modulated current source using the optocoupler is a simpler circuit and has less stability issues.
Putting J2 in the store means putting Semisouth's also in the store.
Unless you use MOSFETs in its place, but it is not a J2 anymore.
And you still need 2SJ74's, which is not an active part.
My 2 cents,
Patrick
music soothes the savage beast
Joined 2004
Perhaps stupid question...can cny17 be substituted with 4n35 without any need for bias tweeking?
