First Try on Tube Preamp
Ok this is my first try for tube preamp, your opinion on the circuit will be highly appreciated.
Below is my operating point for 12AU7 twin triode connected in parallel:
Plate Voltage = 185V
Plate Current = 7.75mA
Grid Voltage = - 6V
Thanks in advance....:) :) :)
Hi s2kov,
Yes, your working point is o.k.
if you want less distortion try 15k at anode
and 200 at cathode. You still have 5V peak to peak before
saturation. Gain will increase of 1.8 db. But output res will rise from 2.5k to 3.2k OHm.
Speaking about output res it seems quite high.
I will consider the use of an output buffer or of an SRPP stage.
...by using a 180 ohm resistor and a 47ufd capacitor on each cathode...
if res and caps as to be put at each cathode (advisable thing) the value of res has to be doubled and the value of caps halved to retain the original characteristic.
Bye
Federico
Hi Federico,
Thanks for the help! Actually, operating point for each section of triode tube, Rp is 15K and Rk is 744 ohm. Since the design is connected both halves in parallel, Plate current will become 15.5mA (7.75mA + 7.75mA) thus, Rp = 7.5K and Rk = 372 ohm
Is it right?
How did you get 200 ohm for cathode resistor?
Andy
diyAudio Senior Member
Joined 2002
How I wish I have a schematic
Nothing special about it....
I don't know why it's said to sound so good, I suppose it all depends on what you're used to.
Technically speaking it's about the only topology I'd avoid using, the whole thing works like a badly balanced see-saw.
Sorry, if you want a really good preamp it'll have to be a little more than just that one.
Cheers,;)
Jojo,
I just choose 12AU7 for my try on tube preamp design. That's why i'm collecting opinions from tube gurus here to let me know if indeed i'm doing my homework right.:angel::angel::angel:
Salamat kabayan!
Andy
JojoD818 said:
Kabayan s2kov!
I see you are using 12AU7, the foreplay preamp of bottlehead uses 2 of those. Unfortunately, I think it is copyrighted so no DIY! :bawling:
JojoD
Cheers,;)
Nice way of putting that see-saw thing Frank. I have seen writeups about that preamp so many times and keep on wondering when can I try it.
Thanks Frank!
s2kov,
You're welcome kabayan!
fscarpa58 said:
Hi s2kov,
Bye
Federico
Is this what you mean? Will i still get the an operating point right?....:confused::confused::confused:
Hi s2kov
The resistor values I have suggested (ra about 15k and rk about 200) come from simulation
(I use Micro Cap 7 demo). These values allows for lower distortion.
Regarding the duplication of the resistance to assure more similar static current in case of badly matched tubes, the values are reported in the following pic.
Ciao
Federico
quote:
Originally posted by JojoD818
Kabayan s2kov!
JojoD
nonsense, this is a standard design, you cannot copyright something that has been in text books for at least 70 years. go ahead and build what you want.
Also I dont think anyone can stop you for copying a patented or copyrighted circuit for DIY purposes, what you are not allowed to do with a patented circuit is to build it and sell it . For copyrighted material you are not allowed to publish it without owners consent.
For DIY, use whatever patented or copyrighted circuit you want if you can find it!
Regards Hans
