First One - mosFET amplifier module
First One GB list update
Hi guys :wave2:
So far 82 First One modules ordered as confirmed on the list bellow. :)
For any new order placed, please quote the list in a new post and add your forum name at the bottom. ;)
Thanks. :cheers:
luca 4
danny_66 2
woofertester 4
rainerco 2
pinnocchio 4
giannettino 2
jokari69 2
mksung 2
ZZoran 2
Edgar 2
Eric06 2
kimon 2
maxidcx 2
e-bok 6
bobo le chat 2
metallicus69 6
scoutOne 4
Iduarte1973 2 (full kit)
quan 2
Greg Stewart 2
colesey 2
analogsa 4
Brianco 2
Theodosis O. 2
chunek 2
Darb 4
CaféNoir 4
Nikitas 2 (full kit)
meanman1964 2
supernet 2
2 modules please.
luca 4
danny_66 2
woofertester 4
rainerco 2
pinnocchio 4
giannettino 2
jokari69 2
mksung 2
ZZoran 2
Edgar 2
Eric06 2
kimon 2
maxidcx 2
e-bok 6
bobo le chat 2
metallicus69 6
scoutOne 4
quan 2
Greg Stewart 2
colesey 2
analogsa 4
Brianco 2
Theodosis O. 2
chunek 2
Darb 4
CaféNoir 4
meanman1964 2
supernet 2
jeremysk 2
Joined 2002
luca 4
danny_66 2
woofertester 4
rainerco 2
pinnocchio 4
giannettino 2
jokari69 2
mksung 2
ZZoran 2
Edgar 2
Eric06 2
kimon 2
maxidcx 2
e-bok 6
bobo le chat 2
metallicus69 6
scoutOne 4
quan 2
Greg Stewart 2
colesey 2
analogsa 4
Brianco 2
Theodosis O. 2
chunek 2
Darb 4
CaféNoir 4
meanman1964 2
supernet 2
jeremysk 2
Dane 2
luca 4
danny_66 2
woofertester 4
rainerco 2
pinnocchio 4
giannettino 2
jokari69 2
mksung 2
ZZoran 2
Edgar 2
Eric06 2
kimon 2
maxidcx 2
e-bok 6
bobo le chat 2
metallicus69 6
scoutOne 4
quan 2
Greg Stewart 2
colesey 2
analogsa 4
Brianco 2
Theodosis O. 2
chunek 2
Darb 4
CaféNoir 4
meanman1964 2
supernet 2
jeremysk 2
Dane 2
mikvous 2
luca 4
danny_66 2
woofertester 4
rainerco 2
pinnocchio 4
giannettino 2
jokari69 2
mksung 2
ZZoran 2
Edgar 2
Eric06 2
kimon 2
maxidcx 2
e-bok 6
bobo le chat 2
metallicus69 6
scoutOne 4
quan 2
Greg Stewart 2
colesey 2
analogsa 4
Brianco 2
Theodosis O. 2
chunek 2
Darb 4
CaféNoir 4
meanman1964 2
supernet 2
jeremysk 2
Dane 2
mikvous 2
presapian 2
:D
luca 4
danny_66 2
woofertester 4
rainerco 2
pinnocchio 4
giannettino 2
jokari69 2
mksung 2
ZZoran 2
Edgar 2
Eric06 2
kimon 2
maxidcx 2
e-bok 6
bobo le chat 2
metallicus69 6
scoutOne 4
quan 2
Greg Stewart 2
colesey 2
analogsa 4
Brianco 2
Theodosis O. 2
chunek 2
Darb 4
CaféNoir 4
meanman1964 2
supernet 2
jeremysk 2
Dane 2
mikvous 2
presapian 2
coolewater 2
I am also interested in the full kit (Chassis, power supply)...
Here you go. :up:
luca 4
danny_66 2
woofertester 4
rainerco 2
pinnocchio 4
giannettino 2
jokari69 2
mksung 2
ZZoran 2
Edgar 2
Eric06 2
kimon 2
maxidcx 2
e-bok 6
bobo le chat 2
metallicus69 6
scoutOne 4
quan 2
Greg Stewart 2
colesey 2
analogsa 4
Brianco 2
Theodosis O. 2
chunek 2
Darb 4 (full kit)
CaféNoir 4
meanman1964 2
supernet 2
jeremysk 2
Dane 2
mikvous 2
PreSapian 2
coolewater 2
Thanks for the confidence. :)
Damping factor
Today a guy from a local audio community called and asked about the damping factor of the First One amp module because it is not specified in post #1. I said that along the THD measurements I noted Zout to be under 10 mOhms, but in reality did not measured it very precisely or specifically on different frequencies.
So today some measurements were performed in order to determine Zout and consequently the damping factor (DF).
Sine signal of 100 Wrms on 20 Hz, 1 kHz and 20 kHz was thrown onto 4,08 Ohm load resistor, measured with FLUKE 289 True RMS Multimeter and here are the results.
1. 20 Hz, 100 Wrms/4,08 Ohm:
unloaded output: 20,205 Vrms (Iout=0)
loaded output: 20,199 Vrms (Iout=4,95 Arms)
voltage drop on Zout: 6 mVrms
Zout(20 Hz)=6 mV/4,95 A=0,00121 Ohm
DF(20 Hz)=Rload/Zout=4,08 Ohm/0,00121 Ohm=3371,9
2. 1 kHz, 100 Wrms/4,08 Ohm:
unloaded output: 20,201 Vrms (Iout=0)
voltage drop on Zout: 2 mVrms
Zout(1 kHz)=2 mV/4,95 A=0,0004 Ohm
DF(1 kHz)=Rload/Zout=4,08 Ohm/0,0004 Ohm=10200
3. 20 kHz, 100 Wrms/4,08 Ohm:
unloaded output: 20,207 Vrms (Iout=0)
voltage drop on Zout: 8 mVrms
Zout(20 kHz)=8 mV/4,95 A=0,00162 Ohm
DF(20 kHz)=Rload/Zout=4,08 Ohm/0,00162 Ohm=2518,5
Measurements specifics:
True AC voltmeter probes were connected directly to PCB output terminals, so no load's wires resistance voltage drop in the loop. Any mOhm of the wires and terminals resistance added in the equation will influence significantly to damping factor value. :yes:
luca 4
danny_66 2
woofertester 4
rainerco 2
pinnocchio 4
giannettino 2
jokari69 2
mksung 2
ZZoran 2
Edgar 2
Eric06 2
kimon 2
maxidcx 2
e-bok 6
bobo le chat 2
metallicus69 6
scoutOne 4
quan 2
Greg Stewart 2
colesey 2
analogsa 4
Brianco 2
Theodosis O. 2
chunek 2
Darb 4 (full kit)
CaféNoir 4
meanman1964 2
supernet 2
jeremysk 2
Dane 2
mikvous 2
PreSapian 2
coolewater 2
edionysus 2 (full kit)
