Filter brewing for the Soekris R2R
Yes. But it might be
set filters = soft
filters with an "s"....
Or was it the help description given by ? that has it wrong?
No, set filter = soft is the correct syntax.
filters is for viewing the list of current filters (add all to see all).
# set filter = soft
F7
# filters
07 NewNOS, 44.1Khz Samplerate
11 NewNOS, 352 Khz Samplerate Bypass
29 DC Blocking IIR, 352.8 Ksps, 2 Hz HP 1st order
30 Deemphasis IIR, 352.8 Ksps, 50/15 uS
While you are in uManager, the proper syntax is : set filter = linear (or mixed or minimum or soft)
linear corresponds to F4, mixed to F5, minimum to F6 and soft to F7
It doesn't matter which filters pack you have loaded, the commands remain the same.
