FET amplifier
russel_h said:
Not quite sure what you mean, I used the balance equation in Hawksfords paper to get a set of resistor values that were close to preferred values. Once you have done that then you should not need to change them.
regards
Sorry for my poor English:bawling: .
OK.You just answer my question;) .Thanks again.
good luck
X.G.
>Whats the voltage of this design? I think that error correction makes >the amp not so efficient in using Vrails, because the error correction >itself needs some voltages to consume. The voltage losses is big.
OK if you are on a limited budget for mass market products its not a technique to use, but its not that large compared the Vgs needed to get a FET to pass a large current. You could run the error correcting circuit off higher voltage rails if you think its a problem. I think its worth sacrificing a few watts for the increase in sound quality EC brings. The supply voltage I use is about +/- 50 volts.
Hi, Russel,
For ordinary power amp, we can easily arrange 2PS to overcome drops like Upupa Epops said. But there is a serious problem if we try to use 2 PS for error correction type amp. Assume we use +/-70V for front side while the output stages are +/-50V. Both PS have to turn on and off at exactly the same time. If not, while the output is tied to speaker, the drivers around the VBE multiplier/VAS will be burned, because the final stage acting as Diode connected to the speaker.
Since EC have better efficiency with 2 PS, I still dont know how to arrange these 2 PS safely. Do you have an idea how to use EC with 2 PS?
Try using an arrangement as in the diagram, if you add T1 as shown both FET and driver aill have there own current limits. Obviously the lower half needs a PNP transistor in its appropriate postion. If you need more current make up the 56 ohms with two resistors, the bottom one setting the current limit.
