FAOW
Pass DIY Apprentice
Joined 2001
Would this be too big? ;)
I don´t have any data or spice-model of the LU1014D, but one should be able to build something similar to this with normal parts.
Here is a balanced single end, fully DC-coupled one-or-few watt amp based on the LU1014D JFET.
I know the self biased common source (short but good explanation in Mr. Rothacher paper). If I´m copying blindy I would not ask the question about the need for input coupling capacitor. I´ll place them on PCB so no problem if source isn´t clean of DC.
Thank you.
JP
If the source is not clean then you should clean it at the source (by cap or servo).
The circuit itself is (should be) Gnd referenced.
IMHO there is no need for an input cap (best cap is no cap).
(Unless you are making a product and want it to be idiot proof.)
And IMHO there is no need for a PCB, which is the whole point for its simplicity.
P2P is just fine, with or without a Vero.
Patrick
