Fake *******ING "MOTOROLA" Transistors
vectorplane said:
PS. you cannot conclusively condemn the merchant who has Toshiba 2n3055's, since it's not unusual for semiconductors to float around in the market for 5 years, 10 years, or more.
And what exactly are you trying to accomplish by confronting the merchant with an accusation?
I would think that if you take your cap meter in there and get a bad reading, you'd say " I'm sorry, this part doesn't match my requirements, do you have any other batch?" He might then bring out some good ones. It's probably more useful than banning yourself from that store (and many others) forever.
Andy
I Agree with you, but I bought a lot of parts (fake) from that store, and I tryed to explain to them, very nicely, that those componets were fake, and that they are not trying to trick me, but that they were buying fake components without know.
Almost nobody here have ever heard about fake transistors, including the stores...
I lost lots of money there, and as I said to you, I tryed to explain nicely to them, to change my componets (those that I've not used) for true ones, or substitute to other parts like Capacitors etc. They were inflexible, and very rude.
:whazzat:
Now, I'm buying from other store, and had the same problem, but they changed my components, and now they are learning about fakes. :nod:
Thanks !
Cbe Readings
Hi All,
Lenten vacation is a good time to get those capacitance readings:
Capacitance, Base to Collector, using a Capacitance meter with 0V bias and test voltage of 150mV; parts straight from OnSemi; values in nF:
MJL3281: 8.92, 8.91, 8.88, 8.89
MJL1302: 11.51, 11.48, 11.44, 11.46
MJ21196G: 5.78, 5.98, 6.15, 6.02
MJ21195G: 7.31, 7.32, 7.35, 7.35
Known FAKE Toshiba trannies:
2SC3281: 2.43nF
2SA1302: 1.11nF
Anyone else willing to contribute? Please post!!
Cheers
Clem
Joined 2004
Hi clem,
I have done some B to E capacitance measure and my readings are the following (0.150mV test voltage, 0V bias, 1kHz) :
The following are all ON Semi transistors :
MJL3281 : 8.8903, 8.7452, 8.7490, 9.0576 nF
MJL1302 : 12.396, 12,342, 12,236, 12.262 nF
MJE15031 : 1.3435, 1.3486, 1.3400, 1.3511 nF
MJE15030 : 1.9194, 1.9084, 1.8905. 1.8423 nF
MJE 4502 : 1.8601, 1.8699, 1.8720, 1.8810 nF TO3
The following are all ST transistors :
BD139-16 : 142.68, 145.82, 146.43, 144.82 pF
BD140-16 : 130.91, 137.14, 134.14, 136.16 pF
MJ802 : 1.3630, 1.4971, 1.3847, 1.3940 nF TO3
Fakes : in the next post.
rephil
Joined 2004
Hi clem,
My availables fakes range from 393pF to 3.07nF for the 2SA1302 and from 893pF to 3.47nF for the 2SC3281.
Before someone write it : yes the resolution of the measure is not meaningful. But it is what I read thus it is what I write, 'AS IS'.
There are different classes of fakes. Not only one of my Toshibas is original.:mad: All fakes. I am ruined... I must Through them all away ... This is a very bad day for me.:bawling:
The distribution of values in capacitance for fakes has no meaning. You can get 5 transistors with very close vlues and others form another batch that are very far away.
Dimensions of the dies are 3mmx3mm for 2SA1302 and 4mm x 4mm for 2SC3281.
Could someone help me in getting a better day ? I am trying to buy some PGA2311PA (DIL) here in Europe and I have no access to Franell being a hobbyist. Pleas where do you buy these PGA here in Europe ?
Thank you.
Best regards.
rephil
Your Toshiba fakes are very likely to be made with dies from other models of slighly smaller power transistors, so they are not absolutely useless. You can always perform some Hfe measurements and some voltage, current and dissipation tests in order to figure out what else you can build with them.
How much fakes do you have? In that forum we have done our best to make clear that almost 99% of 2SA1302/2SC3281 sold in Europe for at least the past 6 years were plain fakes. I have 6 or 8 fakes of various flavours in a bag somewhere (I don't remember). I bought them for fun.
Joined 2004
Hi Eva,
Thank you for your help. I feel better now and I shall try to find some use of these fakes.
I have many (some 30) different fakes. I bought these 5-6 years ago. It was a good deal then, not exceptional though. I shall survive.
Do you know the real size of the dies inside of the Toshibas 2SA1302 and 2SC3281 ?
Best regards.
rephil
Hi rephil,
Many thanks for the capacitance measurements! I am sure we'll find these useful the next time we are evaluating transistors from a supplier!!!
I don't know if anyone is willing to find out the real size of the 1302/3281 dies though... I guess the important thing is, a Cbe of 1/2 (or less) of a real unit is a pretty good indicator...
Does anyone have the Cbe of the REAL toshiba 1302/3281? I understand the On-Semi equivalents generally have higher values (someone mentioned this; due to upgraded SOA ratings)...
Cheers!
Clem
Joined 2004
Hello All,
See by yourself what you get inside fakes : in pic1 you get 3 different 2SA1302 and in pic2 you get 3 different 2SC3281.
It is for this that there are classes of fakes.
As you can see, there are also fakes smaller than 3mmx3mm. I have 2mmx2mm too.;)
4mmx4mm are king sized fakes.:D I have them ...
Best regards
rephil
Administrator
Joined 2004
Hi Clem,
I aina gonna crack open a real Toshiba! :eek:
I did measure mine and found 4 fakes (all 2SC3281A). They are mighty fine fakes at that! There were slight differences in the moulding hole (not flat and clear) and the mounting holes were not cleaned out (over mould).
Measurements were taken with an HP 4263A and 16089B Kelvin lead set. The leads were compensated just prior to the measurements. Settings were 10KHz and 100mV.
2SA1302A averaged 5n7 for the ones removed from a Carver Lightstar PCB, 5n4 for the newer batch I have.
2SC3281A averaged 7n2 for the used lot (5 pcs each) and 7n9 for the new ones. The fake new ones averaged 2n3.
A pic of fakes and good ones.
