F5X -- the EUVL Approach - The Build Thread
I have finally got my protection board working but I lost the 2 seconds delay when powering up the amp from the back panel on /off switch. Meaning to say, once I switch on the amp, the MR led lights up instantly. I think it should be okay since the speakers and inputs are still dis connect at this start up. I use flux to clean up the board but there are still tiny particles in between the really tiny legs of those semI conductors. What do you guys use to clean up the board?
I believe you still have some shorted pins somewhere.
Your 3-state toggle does not seem to behave as intended.
You should clean your PCB properly using a PCB cleaner spray.
And you can remove excess solder from the SMD parts using a thin solder wick.
It helps if you use 0.3mm solder and a magnifying glass, during solder and after (for inspection).
Patrick
You can see the mute and regulator relays (D4) using protective diodes. Some automotive relays have built in diodes. If they don't, you should add one somewhere.
Thanks for the pictures. I can solder the diodes for the speaker relay directly onto the legs of the relay, correct?
