.... where your voltage is funny.
I'm hearing Pa is moving his entire production here ; main reason is Amperage bill , same as fact that here ppl can have properly strong amps , directly mains powered ;
and audiograde fuses are weaker , so cheaper
(not mentioning fact that I can listen da muzak , and drying my hear , in same time )
I'm just glad this is not your 5ch AV unit ....
That just mean.
on heatsinks... I think that ones from the store chassis have a bit to thin base. With not enough thickness of the base you can have a big temp. gradient(hot near transistor and cool further). Thats what I have with my F5T. I ordered 3/8"x6"12" aluminum bars and will use them to increase base thickness of my sinks. I will let you know if it helps.
Does them being black anodized really make a difference, I was looking these. I can get them cut to length.
7.280" - HeatsinkUSA, LLC Store
Unless there is something better then that, for aftermarket.
If you haven't seen it yet. Nice article: Heat sink - Wikipedia, the free encyclopedia
Another thing, I just have no ideas how sinks for the store (or hifi2000.it) have such good dissipation numbers. From my humble knowledge ones from heatsinkUSA should be much more efficient, but they not...
I wonder if that has to do with the density or thickness of the fins.
They are black anodized, the HeatsinkUSA are raw. That will make a difference.
Of course, you can anodize the HeatsinkUSA 'sinks and make up said difference.
I'm not that impatient.
I posted a link in the Solid State heading but as the F5T makes use of a MOSFET output stage I thought I'd ask the question here too. Can anyone please give me an answer on what the difference is between placing the series resistor between the mosfet Drain and supply vs placing the resistor between Source and the load.
On my simulation the series R between Supply rail and mosfet Drain gives the lowest harmonic distortion figure, why?
Here is the original post with schematics of the final stage
http://www.diyaudio.com/forums/solid-state/231535-rd-rs-mosfet-output.html
the C/W ratings depends on temp. if they measure C/W ratings at 80C above ambient, the numbers will look much greater then if they measure at 25C above ambient. there you have the difference.
At given temperatures radiational contribution in heat "transport" will be much smaller compare to convectional contribution. So I would speculate that AudioSan right -- it is more how you measure it.
- F5 Turbo Builders Thread
