I think it sounds better with higher bias
Is that super duper class A?
What are tree huggers?
nigelwright7557 said:
What about the currents going in and out of the capacitor ?
I meant: can you see, looking at the waveform, crossover distortion on a scope with bias upper to 100 mAmps? I do not think so.
AndrewT said:100W of output + 60W of dissipation = 160W of input.
this is ClassAB.bobodioulasso said:And compared to a class ab amp?
The ClassA limit is ~2.6A (= 2 * 1.3A)
Are you saying that it leaves classA when loaded into low impedance
F5 manual dont mention this, so to me not any issue
Its rated as 100% 1-2ohm stable
No mention of not being classA anymore
Why do you say such
Anyway, not all amps doubles output whenever load impedance is half
Its known that some of the bigger PASS designs doesnt do that
(sure hope Im right on that point, but thats what I have been told)
Are you certain that F5 doubles output in half impedance load?
Anyway, if it does, why suggest that the classA bias will be inadequate
Why do you say such
npapp said:My speakers are 4 ohms. My understanding is with a 4 Ohm load I am only in Class A for 12.5W. I am hoping to extend the Class A rating by increasing the bias for the max that my heatsinks can dissipate. If I move to 1.5A bias doesn't this give me up 3A output in Class A increasing the rating a few watts before crossover to AB?
your logic is right.npapp said:If I did this right 1.5A bias would give me 18W class A into 4 Ohms & 1.7A bias yields 23W. Will the increase bias change the character of the amp?
But, you normally set power and sensitivity and normal listening volume so that the peak SPL at the listener's location to about 20dB greater than the average music level.
Based on that 20dB headroom for transients, your maximum average power input to your speakers will be ~ 0.25W.
This is well within ClassA into 4ohm speakers.
If the output goes to 2.5W into your 4ohm speakers (average +10dB) then the peak voltage is still only 4.5Vpk. The maximum current to meet this transient peak is likely to be <=3.2Apk for severe reactance speakers. This is just outside the ClassA limit for a standard F5.
If you increase the bias to 1.65A or 1.7A, then that +10dB transient will be within the ClassA limit.
Only transients that are above the +10dB level will drive the speakers harder. and only if that transient is either very fast starting or very fast stopping will it demand the highest of current to be sent to your reactive speakers.
There's a good chance that you will only go out of ClassA once or twice a recording (if it's very dynamic) when your average listening level is <=0.25W
Hi tinitus
This is a push pull design not a single ended design.
Therefore it stays in class A up to twice the bias current then goes into class B.
If you had a look at my FFT results, you would see that the distortion doesn't look to pretty once you start approaching Class B.
AndrewT said:you normally set power and sensitivity and normal listening volume so that the peak SPL at the listener's location to about 20dB greater than the average music level.
do want yet more numbers?thanh1973 said:
I didn't see what the efficiency of his speakers were.
Are you making an assumption here?
If so what assumption are you making?
I have already posted them.
Gedlee has also posted numbers.
Many others have posted numbers.
thanh1973 said:Hi tinitus
Obviously I dont understand as I expected bias current to be the same for all loads
So its 25watt classA in all loads, is that what you are saying
Anyway, I dont think anything else have ever been promissed
Maybe thats why 300VA trafos are still ok for both channels
25watt classA in 16ohm, 25watt classA in 8ohm, 25wattt classA in 4ohm, 25watt classA in 2ohm, 25watt classA in 1ohm
And the rest is just rubbish
Makes sense
pro said:Is it a good tweek, to put a cap beetwen the mosfet gates? Did anybody try it?
No need -- there is no instability in this amplifier until you run it up into the Megahertz.
The F5 has that wonderful combination of speed, stability and very low distortion.
If you have to tweak, some electrolytics like the Elna Silk 220uF on the rails almost immediately next to the MOSFETs will help. I tweaked up mine to adjust the gate input resistors to the JFETs which has no effect on sound, but makes the slew perfectly symettrical.
Or even better, place your last main supply cap close to amp board
I usually prefer a single pair of caps
But this time I may have multiple caps placed along the entire supply line from bridge to amp board conection
Anyway, I have never understood the use of those small signal supply caps in poweramps
They are not fit for high ripple currents
How that works is beyond me
pro said:It's not for stability, but it, from simulation, looks to lower alot the even harmonics.
That's because you bandwidth limit the amplifier when you add more capacitance to the output device -- usually you do something like this to cure some instability arising from poor lead dressing etc. When you bw limit the amplifier you slow the slew rate as well.
Seems the First Watt or so are Class A .....
- F5 power amplifier
