thanh1973 said:Sorry I am a bit too lazy to give a long explanation.
But it is like this if the output is 25W Class A into 8 Ohms, then it will be 12.5W Class A into 4Ohms, and 6W Class A into 2 Ohms.
Really
Thats the speciality of OTL tubeamps, when doubling its output when load change from say 8ohm to 16ohm
Thats a huge surprice
AndrewT said:
this is ClassAB.
The ClassA limit is ~2.6A (= 2 * 1.3A)
Thi is clear, i was asking: how much dissipates a 100w classAB ( low bias) at 100w output?
tinitus said:I expected bias current to be the same for all loads/B]
Tini,thanh1973 said:
If the speakers he has are 100db/w/m then your calculations would be a lot different for someone else's speakers which might only be 85db/w/m.
The bias is set. It remains unaltered, if the temperature compensation is accurate, irrespective of the load impedance.
The bias determines the maximum ClassA current.
In single ended the bias =Imax
In push-pull bias =IClassAmax /2
Than,
My calculation only used the +20dB & +10dB ratios.
The speaker efficiency did not enter anywhere.
and yes if one chose 100dB/W/m speakers to go with an F5 then you will have higher SPLs available then if one, somewhat stupidly, selected 85dB/W/m speakers to go with the F5s
and the answer is in post4080.bobodioulasso said:how much dissipates a 100w classAB ....... at 100w output?
pro said:The bandwidth is just the same.
I mean a capacitor with one leg on the N gate and the other leg on the P gate.
I thought you were talking about what I saw from Borbely -- recommended a small cap from gate-drain cap of 33pF for the Servo 50 when using the Hitachi (Renesas) Lateral MOSFETs. I think that one of my Haflers has a similar arrangement.
The driver board of the Servo 50 has a 100nF cap across the gates:
http://www.borbelyaudio.com/adobe/servo50.pdf
I haven't done this for an F5 -- will try 100nF and see if it makes any difference.
So, you are saying that into 4ohm, idle bias will be only half (0.6A)
A stereo amp will consume only 30watt pr channel, instead of 60watt pr channel, at idle bias
This situation would mean that one could use smaller heatsinks, for that particular use
And if staying within the classA limit, smaller trafos as well
I guess you are right
I dont question that, but sounds strange to me
So, you are saying that into 4ohm, idle bias will be half (0.6A)
C'mon
That has nothing to do with bias current.
Remember power is voltage times current (=idle bias); for 4 ohm speakers you need only half the voltage to drive the same current through the speaker (Ohm's law), so power into 4R is halfed.
On the other hand, if you have 16R speakers, you get twice the power into 16R (as you need twice the voltage to drive the same current into the speaker).
Don't forget though, that power dissipation in the amp itself is little affected by that in the real world. No chance to get away with smaller transformer etc.
Have fun, Hannes
As I understand it staying in Class A is the ratio of idle current to output current, as Mr. Pass speaks about in several of his articles. Once the output current is greater than 2x the idle current the amplifier starts to leave class A. So following the formula that Papa uses 1.3A bias is 2.6A max output into class A per output device..
The power formula for 4OHM load is 2.6A x 2.6A*4ohms = 25W peak or 12.5W RMS (half of peak)
For 8 Ohm load is 2.6A X 2.6A X 8Ohms = 54W peak or 27W RMS
pro said:jackinnj
try 1u or higher, it do the job.
I've seen 47uF on a design note from nat semi, and 200pF on another design note.
Care and feeding of MOSFET gates --
AndrewT said:Tini,
the answers are given to you in various forms/words and still you won't read.tinitus said:
stupidly like a fox: my mains are 91db and what I am using now... but when I was testing this amp early on I used 85.5 db/w/m speakers. I was able to drive the amp directly from my DAC. One straight wire with no knobs. The combo filled my large room beautifully, but the wife missed the knob
Andrew, thanks for the thoughts on how much output I may actually need for the transients.
Garcia and Grisman are pick'n through my F5
My (bjt) ES200 Audiolabor (Wachowiak) has 1000uf between bases.
We can break this down to make it simpler to understand.
Let's look at only half of the amp. Your rail voltage is set at around 24V so if you have a 4v drop across the fet you have 20v available at the output. The current available is set by the bias current of 1.3A, and that is set by the source resistor. You now have two limiting factors in your circuit, your maximum output voltage is fixed, as is your maximum current. To understand this you must forget about the rest of the amp and just consider this as an electrical circuit and not a part of an audio amp.
The optimum load for max power is easily found, E(20v)/ I(1.3a) = 15.4 ohms, easy enough. Max power is 26Watts
If we use a 20 ohm load then we have 20v/20ohms = 1A which means there is a reserve of current still available but we are at the limit of available output voltage. Max power is 20 Watts
If we use a 10ohm load then we have 20v/10ohms= 2A, but we only have 1.3A available so we are now current limited. Max power is about 17 Watts
This is a basic electrical circuit, please do not try to read anything else into it.
Best, Bill
Well, in that case
I understand that a load into half the impedance means only half the voltage is needed
But is that also equal to whats available
Im really trying to understand your point, but dont
This is really not my strong side, and has nothing to do with "not reading"
But I have always thought that current would rise in low impedance load
Nelson Pass said:
25 watts Class A into 8 ohms implies a 1.25 A bias current.
Its obvious we cannot expect 50watt classA into 4ohm
Perfectly clear
Though to me it will stay 25watt classA, no matter what you say about that
Bias is fixed, supply voltage is fixed
To me its simple logic
And I will build with the suggested trafo rating requested, "more than 10A peak"
Banging my head with better knowing has never worked on me
Obviously I will never understand your calculations
Im even more happy now that all information is easily available, in clear text
Perfectly clear
Hi Tinitus
Staying in class A: two times the bias current in the load is the limit.
12.5w into 16 ohms / bias 0.625A
25w into 8 ohms / bias 1.25A
50w into 4 ohms / bias 2.5A
At 1.25 bias and 4 ohms load we leave class A at 12.5w
when load current reaches 2times the bias current
P peak = 2Prms.
The only formula is P=RxI^2
Is that clear for you?
P peak = 2Prms.
- F5 power amplifier
