I think so. Just remember that the bias will get a lot
higher without the bulb.
Aren't they gonna outlaw light bulbs in 2014?
can you imagine a black market for bulbs to keep pass amps going. NOS GE 100 Watt genuine yellow glow bulb
Ultra LOL
Those are not lightbulbs, they are light emiting constant current regulators.Aren't they gonna outlaw light bulbs in 2014?
Or just plain transducersThose are not lightbulbs, they are light emiting constant current regulators.
Yes, but you need a nine fault battery...
(juma, baš si bezobrazan... )
The F4 has no voltage gain. To reach it's maximum peak voltage output you will need a preamp cappable of about 20Vpk (14Vrms).
OPA552 can swing a lot of voltage with reasonably low distortion. SYN08 used it in one of his HPS pre's.
Worse comes to worse... we could parallel tiny bead thermistors for that negative coefficient.
Someone could build a "Beast with a 1000 Thermistors" amp PCB....
[QUOTE
Someone could build a "Beast with a 1000 Thermistors" amp PCB.... [/QUOTE]
Yes. But that design would not be as "brilliant" as one with large incandescent bulbs....!
Don't know if you'all follow the news from U.S. "Capitol Hill". (Come to think of it, who would????). Legislators are apparently lining up to kill that anti-light bulb legislation. (But I will NOT go into politics in the DIY forums!)
Would be a pity as technically light bulbs are incredibly inefficient.
I just bought a LED-lamp - amazingly nice light, much nicer than a light bulb and being about equally bright to an 100 W bulb. And that with 12 W only!
Unfortunately still rather expensive, but prices are coming down fast with increasing market volume.
Hannes
- F5 power amplifier
