Both amp and PS boards are available.
Nice, I'll PayPal 30$ to your email address tomorrow.
No Citizen crystals available?
Yes, still available:
F5 info: http://www.diyaudio.com/forums/group-buys/140306-f5-pcb-group-buy.html
PS boards: http://www.diyaudio.com/forums/audio-sector/149672-universal-power-supply-pcb.html
Thanks, will ship on Monday.
Delivered this morning. All is fine. Thank you.
I'd like to ask you if I can separate the four boards by hand or I risk some damage bending the whole.
ok i built second channel but same result! not sure what would cause -20 volts at output? there are not that many components to place incorrectly! any ideas?
Confirm that the parts are the correct values. I used 0.91ohm dale mra-5's (for R11 & R12) and only checked one to confirm. Turns out one was actually 90ohm and let the smoke out of the opposite side mosfet.
A bad solder joint on one of the feedback resistors R5 or R6 (assuming R7 & R8 not used) can cause 20v at output.
If you are using the peter daniels boards make sure you have placed the legs of the output resistors in the right place. Also, the 0.47R resistors in parallel with the pots can blow too - you should check them too. Lastly, make sure the pots are turned all the way to 0R for initial power up. It will take a few turns before you see any action across R11 and R12.
Oh yeah, a few pics of the board will help.
Fran
Fran
Hi, Both boards are available.
Paypal in USD to my email address. Shipping included in price of the boards.
- Group Buys
- F5 pcb group buy...
