F4 power amplifier
The 35A will probably be the If rating of the bridge, the slow blow fuse is on the primary of the transformer were the current is much lower than on the secondary the maximum the bridge will see is a function of the output impedance of the secondary winding of the transformer and the // combination of the power supply CRC section and the actual load
(amplifier).
In other words much higher than 2.5 A
(amplifier).
I see, this makes perfect sense. Thank you!
I guess all I need is the working voltage for the 220uF capacitors. Does anyone know what the minimum would be here?
DocLorren said:
Thanks guys for the links to shops for big heatsinks in Europe.
Jaac: pretty impressive chassis you are building there! Mighty tranformer lying left to the heatsink. Your heatsinks will stand up to the task of converting all that current to heat you think?
The amp that you see on the photo's is the finished aleph 5 and having 40 volt dc rails drawing 2 amps thats 160 watts in idle to dissipate by the heat sinks. They get hot, not hotter then a X150.5. tomorrow i will measure the temp of my heat sinks and also of a pair of XA100 to compare with. For the F4 i think the sinks will do the job but i also have some other sinks here at my house and they are bigger and they need some cutting i think to use them for an amp.
I think you can build a nice x1000 with that piece :)
Jase
Transformer question for NP
Nelson
I've ordered a pair of the Plitron 300VA 18v trafos through the group buy. These have the"type 7" primaries which are suitable for 115v or 230v. I'm in the UK and I've just been advised that our mains is in fact 240v +/- 6%. Plitron tell me that these trafos can handle up to 230 +10%, which means they might be just about be ok for worst case of 240v+6%.
Do you use their type 7 trafos in your commercial offerings that are bound for the UK, or do use their type 5 which are configurable for 240v? (Hoping for some additional comfort from you here!)
thanks
Ian
Re: Re: Thanks.
Babowana said:
Hmm . . . good advert.
How come a commercial guy selling the boards of other's in this place?
Meanwhile, why the others wherever they are doing the same blaimed?
Confusing . . . really . . .
:darkside:
As far as I know PD does not make a business on those boards, just check the price. ;)
I see it as a community service for all DIYers... don't kill that attitude!
Formerly "jh6you". R.I.P.
Joined 2006
Re: Re: Re: Thanks.
Well understood.
But, if another guy declares so, the same principle applied?
If I do, it's a community service while if others do, it's a bad thing?
Maybe I'm too extreme and thinking wrong . . .
:darkside:
