I try to do a simulation on hornresp but I stumble on the parameters.
the horns are uneven and I don't understand how to synthesize that in hornrep.
Because the four horns in a Cornu spiral system all have different axial lengths, the loudspeaker cannot be accurately simulated in Hornresp.
https://www.diyaudio.com/community/...peaker-enclosures.223313/page-27#post-3276695
J'ai trouvé ce sujet où l'on trouve un script pour akabak.
je vais explorer l'idée
I found this topic where there is a script for akabak.
I will explore the idea
English please
dave
diyAudio moderation team
That link doesn't work.
This one is working: https://www.diyaudio.com/community/...peaker-enclosures.223313/page-27#post-3276695
Hello Cornu enthusiasts.
I am back to designing a small CNC cornu implementation and am trying to add to my know-how, but doubt I will get to the levels of expertise some of you seem to have. I am designing in 3D and am mainly guided by aesthetics and elegance of construction.
I will post some pics here when I get a little further.
My question for today is about the size of the chamber in which the driver sits - the "hub" of the spirals. What is the impact on the sound if this is bigger or smaller in volume? This chamber is kind of a plenum which feeds each spiral horn.
The little design image at the very start of this thread..
shows the inner square box being significantly larger than the 10cm driver. My design will be curved all the way to the end, not square, and I can either make the ends of each spiral closer to the driver (making the chamber smaller and the horns a bit longer) or I can make this inner plenum space bigger than the driver like in the original sketch above, so there is more room to build it nicely and maybe more breathing room for the driver which might be beneficial.
If I make it as small as possible the open end of the spirals will get compressed together, which is harder to build and fit around the driver, but the horns themselves can be a bit longer (more turns), so I am not sure which is best.
I also have read here about stuffing this chamber with foam or dound absorbing material, but don't know much about how this affects things either.
I will try to incorporate any tips I learn here and share a WIP design with these tips implemented and see what the group thinks.
My horns are all individual end to end and do not split into two like in the original. So, if I am understanding these single horns could be calculated with Hornresp or other software if I provided a CAD file of it to someone willing to run the calcs, but I am not quite to that point yet.
I've no idea what the FR of the horn part is; is it just "bass" or do mids come out there also?
What I find irksome about the design is the immediacy of that back wall to the driver. I've seen many speaker designs that attempt to "treat" the inevitable hard stop to the sound emminating out of the back of the driver - in an enclosure at least. On a scale, I'd envision this "right up against" design at one end, Open Baffle on the other.
Let's say you put a stuffed "traffic cone" behind the driver - then the speaker loses its advantage of being able to be hung on a wall like a painting. Some stuffing sandwiched between metal screens on the back surface would be flatter, but then sound would leak out the back of the speaker, which probably would ruin the whole idea also in more ways than one.
It's an aspect to think about. As long as you're in 3D CAD, one would think there'd be a way to smoothly curve the horn entries upwards towards the back of the driver - looking into the cavity, it'd be like radial fins with smooth curves up to a radius, about the size of the speaker magnet diameter. This means a Neo magnet structure, being much smaller, would give more room to play with the shapes and form of that area.
The design of the horn entry of course would need to match the back of whatever driver is chosen, which could have anything from holes in a stamped metal basket to posts in cast plastic. Since no speaker I know of was designed to accommodate horn entries at its basket, one would have to cleverly choose among what's a given there, to adapt it to such an idea as a "fitted" horn entry Cornu.
Thanks for the reply. The design I am tweaking looks like this -
this is with the front baffle hidden so I can see how the spirals approach the driver. You can see the spiral hit the driver jus below the center of this screen shot. This model is a rough approximation of the Mark Audio Pluvia 7.2.
I can either trim the corner off where it conflicts, or make the inntermost spiral radius about 1/4" bigger so it does not hit, but also does not need to be trimmed. This can only really be understood when I have this built and have the driver to fit around
I am still not clear on how to balance the size of the plenum behind the driver vs the width of the openings to each horn, and the slightly longer horn length which making this plenum smaller would achieve.
Here is a slightly wide camera angle on the same design -
There is an Akabak script for this horn posted in this thread. It is quite comprehensive and the chamber volume is one of the variables. In the scheme of things, given how much variation in the midbass the horn has, although very musical, it’s no “monitor” - the chamber depth is a minor effect. That is, it is not a key driver in the design that impacts the sound. The overall length of the channels and choice of driver is more important. The fact that I have made this by varying the depth quite a bit - and that varies the chamber volume, yet it still works for a bunch of different drivers. So really, it’s not that sensitive to the chamber volume. Don’t make it so big it becomes a reflex horn. Regarding the wall behind the driver, you can add an internal cone to prevent that direct standing wave or add a layer of melamine foam. I have not found this to sound “boxy” at all. Most importantly, make a prototype in a few nights in the kitchen table with foam core to test your design before committing to cutting wood.
You need to install Akabak - (Acoustic Abacus) software. It’s not an easy software to learn but very powerful and about the only one that can handle a horn with 4 mouths. Difficult but all you need is to run the pre made script and vary the chamber volume to see the effect.
There is a thread for Akabak on DIYA.
https://www.diyaudio.com/community/threads/akabak-3.353871/
Here is the Cornu script written by Don Hills:
Change the Depth - and that varies the chamber volume and horn volume. You will see the effect.
Colin,
Forget the plaster, noit stiff enuff. And translam is a HUGE waste here (even more than usual). 3D print it. some sort of skins overtop of a fill such as a bucky-like tetrahedron structure. Acyrilic is fine for a baffle. It is really well braced so does not need to be that thick. Likely a big contributor to total budget.
BTW: answer mfrom reading your email not your post/ I might have more i am abit under the weather ATM.
To approximate, take the circumference of the mouth> In this case, 4 x 2x(33 cm + 10 cm) (guess) = 344 cm. Multiply by 2 since it is wall mounted = 688 cm = wavelength of 50 Hz, below that it is a TL.
Colin: the size of the coupling chamber can be roughly determined using the formula in Dinsdale. Since you are fine tunging the design — i applaudf that — this is a good basik primer on horn design with theoretical formulas.
http://p10hifi.net/TLS/downloads/Dinsdale-Horns-3parts.pdf
dave
dave
Thanks. Hope you're feelin better soon.To approximate, take the circumference of the mouth> In this case, 4 x 2x(33 cm + 10 cm) (guess) = 344 cm. Multiply by 2 since it is wall mounted = 688 cm = wavelength of 50 Hz, below that it is a TL.
I acquired a couple Dynavox LY401F-M01 drivers and want to try my hand at some Cornu Spiral Horns. I hope these will serve as a decent option to work with.
At some point, someone recommended using Gator Foam Board as a stronger, more durable, alternative to basic foam core poster board. They have 3/16", 1/2", and 3/4" versions. If I wanted to build the internals out of (comparably flexible) foam core, would CNC routing channels into the Gator Board work? Would cutting, say, quarter-inch-deep channels into the 1/2" Gator Board cause structural instability?
I'm envisioning a 24X24" version (or maybe slightly smaller). Do I want the single, or double-chamber version of the Cornu? If I CNC a piece of regular foam core, that could be used as the middle divider, and still have two half-inch Gator Board sections for the exterior.
My trepidation still lies in executing the final-face glue-up. I'm not sure how I'd get all the foam core walls into the slots cut into the last board face. Would it be a better idea to cut the channels wider than the foam core sections, so they'll be easier to insert? Fill the channels with plenty of adhesive, and just hope it'll go together after some dry-fitting? It's not my CNC setup and I'll have limited access. I was hoping to only have to try to access it once. Perhaps I'll just have to experiment with cheap foam-core first, before committing to a final process. I also have no idea how to stuff the thing, and won't be able to change anything once the final version is constructed.
The other thought I had was to use a 2X2' drop-in ceiling tile as a decorative, light-weight, (and VERY lazy), way of finishing the enclosure. Will the extruded 3-D features on the tile mess with the acoustics of the speaker? Perhaps it'll produce better sound with a simple, flat, face?
https://www.amazon.com/Majesty-Anti...?_encoding=UTF8&ref_=pd_gw_ci_mcx_mr_hp_atf_m
Perhaps it may vibrate and buzz if I don't glue it down, properly? That wouldn't be good...
I wouldn’t bother cutting channels into the gator board. It might actually weaken it. If you use Gorilla glue it actually expands and fills voids. Or if you are careful and cut all the channels exactly an even width, they will seal well even with PVA white glue. Use a flat stiff board on top and add lots of weights and books to clamp the final side for glue. One other tip, for your first set, just use cheap foam board. The gator stuff may not bend and roll into curves so easily.
In architecture studio, when foam board was used, stainlesss steel T pins or simple pins were excellent for holding work in place while glueing up pieces. (Would be tough to use with gator board).
I AM VERY OLD TO THIS POST.....SINCE 2017.
I remember, some guy posted COMSOL script for this Cornu Speaker Simulation.......
Can someone help me on this and also guide me regarding patent holder information...I am interested towards commercialization of this aesthetic master piece
This works very well too:In architecture studio, when foam board was used, stainlesss steel T pins or simple pins were excellent for holding work in place while glueing up pieces.
https://it.aliexpress.com/item/1005006782104132.html
I think I've confused things a little. I have read about this project off-and-on, over the last couple years. Somewhere along the line, I got it in my head I'd be better off doing a double-layer style Cornu-copy. Maybe from this site?I wouldn’t bother cutting channels into the gator board. It might actually weaken it. If you use Gorilla glue it actually expands and fills voids. Or if you are careful and cut all the channels exactly an even width, they will seal well even with PVA white glue. Use a flat stiff board on top and add lots of weights and books to clamp the final side for glue. One other tip, for your first set, just use cheap foam board. The gator stuff may not bend and roll into curves so easily.
https://sebastian-pitkanen.blogspot.com/2006/07/cornu-spiral-copy-horn.html
I guess I had been envisioning that center section of board, separating the two chambers. I was thinking about running slots through the inner board, with a CNC rig, and hoping that would make it all uniform. But, in practice, it probably wouldn't work out that way, and the foam core spiral would not be nearly as exact as it would need to be to slide into grooves cut into the exterior, Gator-board faces.
I also don't think I quite understand the difference, or necessity, of a single chamber VS that double chamber, design.
I'm probably over-complicating things - have a tendency to do that.
Does anyone have a preferred way of cutting the foam-core fin sections? Will a table saw give clean, flat, rips? Do I need to just go at it with a razor knife and a good straight edge?
- Full Range
- Ever think of building a Cornu Spiral horn? Now you can!
