To get the DSD I basically hacked a Denon DVD-2910 taking the DSD at the DAC pins. Its actually not much of a hack. Just solder a couple wires.
Sure Buffalo probably sounds better than Opus can. But its also not as simple, and it is more expensive. It should and does perform very well.
That said I won't be giving away my opus.
So the only way to say if it is better or not is to know your priorities. They are both IMHO excellent DACs.
Cheers!
Russ
Cheers!
Russ
Russ White said:
Oh, I remember that now! Did the price ever drop, or is it still $50 a pop and 5 order minimum?
Thank Dougie,
But I like I2S with pure signal, I can build the CD transport with I2S ouput with this DAC
Dougie085 said:The Buffalo accepts SPDIF in its stock form as well so you can just run coaxil to the DAC from your player.
Re: Re: DAC4392 + ESS Sabre: this is incredible.
Hi WMS,
yes i'm player the ESS demo board stock. I'm waiting (do you have any news about Guido Tents?) to receive an XO from Tentlabs to replace the standard 40 Mhz clock.
But the sound, also without any modification, is astounding.
I'm not able to describe in words the beauty of sound of DAC4392 + ESS Sabre bundle.
I would like to understand how I can improve the EVB analog output stage. Do You know a project ready to be implemented?
wildmonkeysects said:Hi hires69:
Are you playing the ESS demo board stock, ie with the included clock and analog output stage?
Also thanks to Terry Demol for the in depth answer bout the 'tails. Impressive output stage compliance.
WMS
Hi WMS,
langtuhanoi said:Thank Dougie,
Yes it does directly take I2S and other PCM formats too.
Cheers!
Russ
MrMajestic said:This DAC looks very promising. To run both SPDIF and DSD input at the same time Im guessing some kind of switch will be required? Would the OTTO do the job? Now, to only find someone to buy my Opus and get hold of a moddable Denon player
Sure you could use OTTO.
I am working on way to make mine switch back and forth between PCM and DSD depending on the mode the SACD player is in, that is playing a regular CD or a SACD. I still have a lot more playing to do in that regard.
For now I have simply checked that DSD input does indeed work.
Cheers!
Russ
Cheers!
Russ
I was thinking of switching between some kind of SPDIF input selector (Darwin?) and a DSD input using the OTTO. Would a RJ45 connector work well with DSD?
- Digital Line Level
- ESS Sabre Reference DAC (8-channel)
