Enclosure For My Speaker
hqDFsw66djyEAOw==
This is the enclosure for LG 7.5inch Woofer
hqDFsw66djyEAOw==
As mentioned earlier in this thread...No, it does not!
these parameters are for LGZ40 7.5 INCH SUB???
7-3/8 woofer by LG. 4 ohms/180 watts. Mechanical Parameters: Fs=50.0 hertz, Qms=4.600, Vas=0.391 cu.ft, Cms=0.045 in/lb, Mms=1.396 oz, Rms=6.058lbs/sec, Xmax=0.138 in, Sd=27.3 sq. in. Electrical Parameters: Qes=0.984, Re=3.5 ohms, Le=0.6mH, Z=4.0 ohms, BL=6.6 N/A, Pe=1800 watts. Single Driver Vented Box Parameters: Vb=1.522 cu.ft, Fb=26.8 hertz, F3=23.6 hertz, Fill=normal, Ports=1 (round), Dv=1.60 in, Lv=3.37 in. These are heavy duty, quality speakers.
So I don't know which kind of enclosure suitable for this drive, which is the theoretically suitable enclosure box for this driver.
A 32.9 L [net] BR with a 5.07 cm^2 x ~1.9 cm [baffle thickness] long vent and damped to 'taste' seems a decent small cab compromise.
If ~2x larger TLs are an option, then up to 5-6 dB higher SPL down to around 30 Hz is a viable option.
GM
