Thanks Dave, but I'm a big enough nerd that I already subscribe to a number of science journals and blogs so I've seen the reports. I even have the CERN app on my droid.
good to see you joining in for embarrassment John.
Zen, why would you want to wreck the resale value of a pair of Tannoy's? Not that they don't need help, they do. But most people who buy them are in it for the flipping capability, onward to someone else who isn't going to listen to them either, just resell them.
I am sure we could work out a set of patterns, but you would have to do the work, having been born halfway around the world and all.... The terribly embarrassing empirical tap test would have to be used. Completely without "proof" of mathematical acceptability.
Bud
Bud
these K3808 are mine
I'll make boobs on them , same as my RCA LC1 have , will try sort of phase plug for pepperpot , and why not EnABL ....
I don't care for their resale value , just because I bought them for my musical pleasure
whatever I choose to do with them , they'll sing better .........
i told bud and others years ago if they want find a reasonable explanation of the enabl thing, then they might look at phononic crystals cuz that looks like what enabl is.
Well Frank, it wasn't that you were ignored. I did look as carefully as my deteriorated brain allowed, but I couldn't draw a connection. Perhaps you could provide either a primer that shows what looks similar to you, or perhaps a later, simpler, explanation from other sources that might show how those applications apply?
Bud
Bud
At the time you rejected the idea because it seemed yet another "added mass" explanation.
Try this:
An introduction to phononic crystals
Well I still want to thank an evaporated Frank for the link to a much easier to understand discourse on phononics.
http://www.femto-st.fr/en/Popularization/An-introduction-to-phononic-crystals.php
Now I just have to interest some Frenchmen in poking their long noses into EnABL.
By the way, the drivers sent to migeO might fit the definition of a two dimensional phononic structure. I am not sure how the discrete patterns found on other drivers might fit, though for some cones, looking at them from a point centered on axis, do look like a form of phononic structure. Interesting.
Bud
Bud
so where's the precise repeatable periodicity in eNabl??? not to mention the precision and accuracy,or the physical scale vis a vis phononic xtals? Lets see an analytical comparison, rather than more hand waiving
I second this! Proof is in the pudding.
Cal, I can't seem to find my recent post in regards to enabling being recommended as a treatment for phase plugs, and the corners of cabinets. These being recognized locations for the treatment, I believe their discussion should be included in this thread.
So for the record, people have had excellent results placing patterns on the corner's of their loudspeaker boxes, and on the tips of their phase plugs. Some of the phase plugs were aluminum, and some were turned wood, but both kinds were rigidly affixed to the pole piece of the magnet.
The merits of these two placements escape me in detail; would someone who has tried the pattern there please refresh my memory (and go on record) of their effect?
Thanks.
Thanks.
Banned
Joined 2002
no proof, just LOTS AND LOTS of speculation!
Here's a technical question (hopefully won't get deleted).
I've seen a few measurements of the difference from Migeo I think. Perhaps Bud can post the link again.
So if it can be measured once, why not again? I think something like this can be measured. Perhaps not easily. And not with a frequency response.
Also, some of the claims should be easily measured, like elimination of room modes and perfect off axis response. That's measurable. Is this hyperbole then?
Banned
Joined 2002
you know which size is Cal ?
you really don't want to **** him off
i know what size cal is, cal is a awesome person, seen him many times.
I have no beef with anyone, just trying to see some actual proof on this site about the "claims" of dot's on cones.
YET no video proof has been show, only verbal ones..
Cal is 9.2 Links and 16 Stone, 3 pounds.
Does anyone have anything to add to the technical side?
Yes. Based on what I heard from enable (I wrote a review indicating I barely heard a difference if any), and what I previously measured (back in this thread somewhere) using basic measurement techniques, and the measurements I've seen posted (very few), I think if there is a difference it's related to CSD. CSD testing should be carried out in some controlled method.
It would be new territory for me, but I'll do testing for anyone who can provide 4 untreated drivers and then treat them.
- EnABL - Technical discussion
