ECL86 preamp?
diyAudio Senior Member
Joined 2002
Zo.
What are the consequences of increasing output impedance ?
In order to transmit properly from one stage to another output and input impedance need to be low at the sender end and high at the receiver end.
Often a ratio of 1/10 is prefered, say a 10K Zo source driving a 100K Zin.
Disrecpecting this rule will inevatibly result in loss of fidelity.
Basically you best drive a high input impedance witjh a low output impedance.
Other factors play a role too, I just want to get the basics across.
Cheers,;)
Ooops, shame on me :idea:
Since I began to tweak using you suggestions, I was looking for the cause why my preamp was "so powerful". I finally found out that my supply was providing 325Volts instead of 285Volts which is a bit over the nominal maximal voltage. (300 Volts under normal use).
Well, I guess from now on I'll look for a new tube design ?
I'm looking for a ridiciously simple preamp. I've seen the 6sn7gtb preamp and I'm looking for similar schematics... Any ideas ?
Thanks !
If you have any troubles reading French, maybe you should try Altavista's Babelfish
BabelFish
and then enter the following URL
http://dan.bellity.online.fr/haute-fidelite/DIY/LED-mu-follower/DIY-mu-follower.html
I hope this will give you an idea of what the article means.
URL
http-"dan.bellity.online.fr/haute-fidelite/DIY/LED-mu-follower/DIY-mu-follower.html"
is death in the meantime. also webarchive in the Moment due Service and maintenance.
Who can upload the shoot-screen of this describtion ?
I want to have a unity gain line amp either as cascode-follower with resistor current source or as normal follower and active current source according this:
the Power Folllower
thanks also for additional hints resp. advices.
The aim is getting lowest possible output impedance
