I had a chronology of "Curve Tracer" articles in the microprocessor unit I described for AX about 10 years ago. There was a great article in "Ham Radio" describing a unit a fellow had developed to trace ham amplifier tubes.
I have since acquired a Tektronix 576, and have bought and sold via EBay auxiliary units made by Heath and Eico. I think tracers of this nature are good to demonstrate device properties, perhaps to a physics class, and to match devices, but to make your own SPICE models nothing beats dropping the data into Excel, or at least saving as a CSV file.
You have to talk nicely to the Tek 576. The CRT's are very difficult to replace and most have led lives of abuse. I don't think anyone has seen at 576 where the safety interlock hasn't been purposefully defeated!
The new version now have long-term stabilityYou can follow the link in post #36 and contact Locky_z to buy one of his.
It can also do high current, just that it has no long-term stability and accuracy.
And we want to use them for matching, so we need long-term stability and accuracy.
But maybe it is fine with what you want.
Patrick
New circuit see below page
http://www.diyaudio.com/forums/solid-state/151253-diy-curve-tracer-pc-5.html
Perhaps you can tell us what temperature coefficient those ceramic power resistor you use would have ? Also I see that those resistors are stack one above the other without air space in between. I wonder how hot they might get in continuous operation (rather than a single shot per minute or so).
Further more, I expect that at 40V 3A, those power transistors of the dynamic supply will dissipate quite a portion of that 120W. I wonder how hot do they get, again in continuous operation, on the aluminium heat sink that you showed in your photos.
Thx for sharing your progress. We have decided to make our own, write our own software, and design our hardware from scratch. Our version will eventually be able to support continuous operation at full power (40V 3A), and sufficiently dimensioned power MOSFETs (12x TO247 devices in total) on large finned heat sink, and will use reference resistors throughout, with temperature coefficient of 50ppm/K or less. These are loaded to maximum 30% of the rated power, and are all mounted on heat sinks in addition. The hardware will have its own µP and linked to the PC via USB (no RS232 required).
Best regards,
Patrick
PS For us, long term stability means at least one year between calibrations, and all curve tracers cross calibrated. Cross calibration is necessary as we are measuring devices at 4 different locations over 3 continents.
Best regards,
Patrick
The most temperature stability is ADC input resistor (91K/12K),Perhaps you can tell us what temperature coefficient those ceramic power resistor you use would have ? Also I see that those resistors are stack one above the other without air space in between. I wonder how hot they might get in continuous operation (rather than a single shot per minute or so).
Best regards,
Patrick
The ceramic power resistor is no important.
I hard to explain it with English,If you understand Chinese,then browse link
ÖÇÄÜͼʾÒǵڶþ°æÉè¼Æ½ø¶È - ÒôÏìDIYÂÛ̳ - HIFIDIYÂÛ̳ - Powered by Discuz!
of 235#
Yea, I agree, 6 years is long wait. I admire your patience. I once waited 6 minutes for something!
Anyways, who has actually built or used the MOSFET tester? I must also admit that I know little about the actual use of MOSFETs. I of course have hear about the open sounding analog power amp they are capable of.
Where I am heading with this is that I have (2) Yorkville EF508p which use MOSFET in their LF and HF biamps. One of the units is blowing the main fuses that fast! It turns out that it uses NOSFETs so I am not real sure about the aproper approach to test them w/o service notes, etc. So, I am looking for a tester that also handles MOSFET. I have found only two: the ELEKTOR discussed in this article and one currently on eBay made by Peak Atlas DCA for ~$80USD. Which one is recommended?
The Yorkville EF508p usesthese MOSFETs: 1RFP140N, 1RFP9140N, 1RFP23N50L. Some versions apply a 'crowbar' circuit in this porduct series. The IRFP's are very hard to locate! Right?
Suggestions please.
Thanks,
Should I purchase the
Suggestions please.
Thanks,
