Diy monoblock 700Wrms/2Ω
Thank you all for your kind words.
I made a mistake in the pics of post 18.
Here are the correct ones :
First pic is the output without a load, driven at full swing at 100KHz
In the second pic i have only changed the setting on the scope to measure
voltage (p-p). As you can see, its 142V p-p.
This test was performed to check the stability of the amp.
In my opinion, not all mosfet amps can do this.
