Thanks for the interest in my project.
Base plate is of (5mm = about 3/16 inch) polished aluminium. I made the base plate with holes first, then I assembled the bolts in to the corners. Transformers and sockets then and after all wiring I made the wooden panels.
I liked this way when I invented this. I had a lot of room to make wiring etc. and no worry to break wooden parts. Steel bolts are very stable to support heavy plate and transformers (40 pounds) during building and later on. I had also bolts on the top side during building to secure tubes in testing phase. And you can adjust height of the chassis freely afterwards to keep the device aesthetically balanced.
Bolts are of ordinary galvanized steel. Bought from the nearest ironmonger for a couple of bucks (3$/pound). SS bolts are (here in Finland) a little bit too grey in color compared to aluminium plate.
Output transformers are Edcors.
https://www.edcorusa.com/
Power transformers and chokes are Hammonds.
Hammond Mfg. - Transformer Index
Thanks.
-jouni-
Thanks.
-jouni-
The schematics here:
One more figure, tube mounting plates assembled.
Noval tube plates not ready yet, I have to look for smaller ones.
- Tubes / Valves
- DIY KT88 SEUL
