DIY 4 Phase Sinewave Generator for Turntable Motor Drive
Hi. I got my chips from Ted, but no response in arranging for firmware upgrade.
Btw, a sincere thanks for having done all of this. I have been wanting for some time to use my papst auss. motors as 3-phase, and the only decent solution prior to your offer was Siemens industrial psu's.
So, thanks again.
Thanks to Ralph for getting PCBs and chips out to me a week or two back.
The SG4 is done, it came together quick and easily, worked straight off the bat. Very neat indeed, its a lovely little thing!
I'll make a chip amp and an enclosure to go wih it over Christmas break, will post again as it progresses.
Cheers
Glyn
Cheers
Glyn
Well, I'd intended to build an amplifier with a pair of LM3886. Just out of interest I connected the SG4 to a class D amp that uses TPA3116. I was quite surprised to find it can drive my Lenco L75 at 200v without breaking a sweat! It's been running now at 200v 50Hz for 3 hours, the TPA3116 is just under 35 degrees, with a ridiculously tiny heatsink. Voltage and frequency are rock solid.
Power is from a remote 24v SMPS, so the SG4, amp pcb and output transformer will make up into a very compact device. I'm made up, can't wait to get out to the shed after xmas and make a box!
Cheers
Glyn
Glyn-
Glad to hear it is working out.
If you are powering the SG4 from 24VDC, you may want to add a heat sink to the main 5V regulator. I think the input can handle 26V, but it is going to dissipate quite a bit more heat than if powered by 12V. Just a thought.
You could also mount the regulator off-board on a heat sink, or mount it on the other side of the SG4 board which would give it more room for a heat sink.
Hi folks since, I will be handling US distribution from here on out, I want to let everyone know how it will be handled. It will be at a cost only basis, the chips are $6.00 each. The shipping is $6.80 via USPS Priority Mail small flat rate box. Additional chips will be $6.00 each, no additional charge for shipping multiple chips in the same order. Tracking numbers will be emailed at time of shipping, Payments via PayPal only please. If you send payment as a gift you will pay the PayPal fees, if you send as goods please add 2.9% plus 30 cents per transaction to cover the PayPal fees. I think it is best if you contact me by email: twystd3atyahoo.com rather than through the forum, as my private message box could become too full (plus it saves a little bandwidth), that is also my email linked to PayPal as well. Looking forward to help getting some projects up and running.
Have fun,
Roe (twystd)
