Directed 1500D
All of the outputs are removed right now since some were defective..
Amp is still stuck in protection mode..
Heres what i get on the 494
Pin1:0
Pin2:4.96
Pin3:.05
Pin4:4.84
Pin5:1.46
Pin6:3.64
Pin7:0
Pin8:13.04
Pin9:0
Pin10:0
Pin11:13.04
Pin12:13.04
Pin13:4.96
Pin14:4.96
Pin15:4.96
Pin16:4.96
Heres the pics of the board..
They are where the two center wires on the power transformer that go into the board near the yellow cored inductor.
I think you'll find that everything reads 0v. If that's the case, you'll have to remove the transistor that's driving pin 4 high, clamp all transistors tightly to the heatsink and power the amp up via a 15 amp fuse or a current limiter. There is some risk that the outputs will be damaged (I'm assuming that you've checked the outputs and none are defective as of now) but you need to get the amp to power up to find what's causing the fault.
