I firmly believe that the reason no one can get measurements that match the published Fostex data is that we are not using the same set of conditions at home that Fostex uses in the factory. I have built any number of speakers using the Fostex published data and the resulting speaker is spot on to the modeled data. We had this pi**ing contest over manufacturers publishing fictitious spec a while back.By this time in my career, I pretty much know whose data to believe and whose to ignore. Fostex is one I believe.
Bob
Bob
Must be a older design with the Radio Shack full range driver's? Jeff
That was directed more at Dave as its design details aren't in the public domain per se...........
GM
Good to know, thanks! I've no hand's on experience with them beyond the old Foster drivers, only done sims for other's using published specs.
Altec was another that didn't 'play by the rules' WRT T/S measurements, they used the American 4 ft distance.
GM
GM
Okay gotcha ya. Dave is the man. Jeff
OK, after looking at the specs, what is the intended app, your performance goals as all I'm seeing is a near-field app without BLH loading.
GM
Yes a near field monitor size without the back loaded horn foot print. Jeff
… we are not using the same set of conditions at home that Fostex uses in the factory
More detail -> http://www.diyaudio.com/forums/soft...rements-book-win-mac-linux-4.html#post4657538
dave
- Full Range
- Diffractions on the front speaker baffle?
