Is this GB still on? i would like to buy 1 + 2 + tube output and i need power supply too.
yes!
thanks
yes!
thanks
Ok, what is my next steps?
Please waite for GR 3 , some day with full kit .
and you can see some in for may tin in 6 moons
Hi!
this new:
http://www.diyaudio.com/forums/group-buys/315257-dac-es9038-oput-tube-gr-3-a.html#post5254417
thanks
Quanghao, I have the ES9018 ver 2 dac, how do I use the onboard 3.3v instead of the USB supply. Is there a jumper to set? or remove? on the DAC board? Can you please provide some information? I am going to use the I2S input, but I have to activate the 3.3v supply, please help.
Alex
Alex
Hi!
Please try to go to this link: http://www.diyaudio.com/forums/group-buys/315257-dac-es9038-oput-tube-gr-3-a.html#post5254417
thanks
quanghao
thanks
quanghao
This is bes for you now. thanks
http://www.diyaudio.com/forums/group-buys/315474-pure-tube-es9038pro-9028-9018-akm.html#post5259820
thanks
quanghao
thanks
quanghao
Thank you Quanghao, ok, so $45.00 for the tube output pc board, $35.00 for the power supply and $25.00 for the shipping, so $105.00 total?
Can you also add the 3 heatsinks for the power supply and the 4 output capacitor for the tube output, please? if so, how much are they?
Thanks Quanhao, you do fantastic work,
Alex Deveza
Alex Deveza
Yes i can Buy all for you From in :Parts ConneXion - The authority on Hi-Fi DIY parts and components
With price the sample in PCX
But I think the ship go up.
Thanks Quanghao, I already have a lot of parts on hand, but I am just looking at the pictures, would you mind sending me the schematic and parts list so I would know what I have already? I already have tubes, sockets, diodes, etc. But I only want, what you already have, dont order them for me, just the ones you have. If you do not have the output capacitors on hand, then thats ok, I will order them myself. Maybe, I need those power connectors you use, I like those, male and female.
For the tube I/V, I see small relays and balanced outputs and some IC's, for me, all I need is the balanced input and single ended output. I will have to bypass the relays and controls, am I correct?
So I think I will only need the output caps, heatsinks, and connectors and the boards of course.
Thanks,
Alex Deveza
Thanks,
Alex Deveza
- Group Buys
- DAC ES9038 PRO GR 2
