Quanghao,
I'm asking about all of the jumpers labeled 1.2V, and 3.3V. What are these for?
Dear TarnishedEars, I think this is what you are looking for
Hi Raoul,
- See you soon.
My DAC will be at "Le meeting ardéchois V" this week-end.Hello Quanghao, I'd like to change my mind again. I'd like to add the I/V stage kit. Tell me if it's not too late and I'll send you 60$ extra cost. Many thanks. raoul
- See you soon.
Hello Quanghao,
Many thanks.
raoul
ok, you get it!
thanks
Convert PCM realtime to DSD
Hello,
With Foobar it's possible to convert PCM in realtime to DSD, so all your redbook 44.1 and PCM streams can be realtime upsampled to DSD64-DSD512 and played with this DAC
Here's some links how to do it:
- Foobar and converting Flac to DSD128 on the fly
- Foobar 2000 for Dummies
How does it sound ? Well, with DSD256 and DSD512 I had sometimes some distortion, now with DS128 I have the idea that it sounds more open compared to the plain 44.1k PCM,
no big difference, both sound fabulous
Hello,
A. You will receive complete DAC:
And this is the complete picture dac, you see
some of you did not purchase USB, so you purchase or subscribe themselves from me, I will always fitting for you.
Thank you
1. claudio52. DAC Finis without USB
2. Smoothquark DAC Finis without USB
3. Myfavoritettthing DAC Finis without USB
4. NicMac DAC Finis without USB
5. Mattmax DAC Finis without USB
6. gjorgji DAC Finis with USB
7. Masterkey DAC Finis without USB
This looks great! I already have an Amanero. Is the cutout for USB input already made in the back panel of the chassis? Then I will just install it myself.
Really looking forward to receive this DAC!
Hi Quanghao,
I'd like to change my mind again. I'd like to add Amanero interface. Tell me if it's not too late and I'll send you 100$ extra cost.
You can cut me the pcb wire on Amanero module for external power supply?
I will not be home up to 25 of August. You can send me the parcel it later?
FYI - In case anyone is interested, I identified the digikey part numbers for those 4-pin white connectors which are used to connect the analog boards to the main board.
455-2267-ND
455-2261-1-ND
Yes I know, I'm packing, shipping will be tomorrow!
Don't worry, take your time. I don't want to place any pressure you.Yes I know, I'm packing, shipping will be tomorrow!
I was just sharing something that I finally figured-out which other group-buy people might care to know as well.
would like to thank you and everyone!
quanghao
Pm all you get after dac, dac kits all, has been welding shield
Hi all,
Anyone facing the same issue as mine that the output volume level can not be saved?
please make it again, it is easy
- More Vendors...
- Quanghao Audio Design
- DAC-END R (ES9018) full assembled board
