Hi Quanghao, when you will proceed with the shipment of B List ( post #884 )?
Claudio
ok, i check it!
thanks, please waite!
thanks
Hello Quanghao,
Do you think you will be able to deliver B list (kmajjo) in the future , because i sent you 60$ some month ago and there is no new from you on this post ?
Br
Jacky
please pm me, what i can say all!
thansk and im sorry
quanghao
Hi, I am interested in the group buy for all the DAC parts with Lundahl output transformers. Could you please point me to where I can find the original list of what can be ordered and prices? Thanks
please go to thí for GR3:
http://www.diyaudio.com/forums/quan...-board-version-2-group-2-a-7.html#post4286452
thanks
Hello?
I am interested
DAC-END R (ES9018) full assembled board - version 2 - group 2
1) DAC module assembled and tested with all components (price 450$)
6) LL1684 output stage only (price 420$ (price for 2 modules L & R))
Please let me know How can I order and pay.. my country is south korea..
thanks.
I am interested
thanks.
Hi quanghao! I have a few important questions that remain unanswered in previous reports:
1. Why ISO7640 does not break ground source and DAC? This is indicated in the description but I think it does not fit the description of the DAC. How to fix it?
2. Why is the earth current-voltage (I/V) module is connected to the frame via the screw that secures the connector neutrik? Do I need to unscrew the screw that there was no connection of analog and digital ground which is on the case?
3. Do I need to remove the jumper from the SPDIF input to separate transformer worked fine?
Please answer my questions.
General questions
Anyone who has a DAC already - I would be pleased if you could answer a few simple questions
How easy would it be to add the Lundahl output transformers later?
Would anyone recommend not buying the case, or would it be very difficult to put the electronics in a case (lots of cut outs etc.)?
Is 1,4,5 a sensible option (no case)
Is 1,4,5,6 a sensible option to save cost (no case?)
Is it just a case of assembly or is setting up required?
no need!
thanks
DSD Crackling/Noise
Quanghao,
I have a problem playing DSD256 and DSD512 using JRiver and Foobar.
I hear a crackling noise (right channel only) and after a while it turns into digital hash noise (again, right channel only). Is there something wrong with my settings? Both foobar and Jriver are set up to bitstream DSD (DoP) directly via ASIO.
Thanks!
Quanghao,
Thanks!
Quanghao,
Thanks!
hi please check seutp of JRiver , and run USB with supply from your computer!
thanks
thanks
Thanks for the quick response!
I've checked (and double-checked) all the settings. Everything on my computer is correct. I have always had this problem with DSD256 and DSD512. However, DSD64 and DSD128 both play perfectly.
What do you think the problem is?
What do you suggest?
Thanks!
oh, no, no, Amaner ro can not run with DSD 256, i test many tim, and it is not run good!
im sorry
quanghao
Okay thanks.
I'm glad to know that it's not my issue.
Thanks!
hi!
my be DSD 256 AND 512 NEED more current for clock 100 mHz and 1.2 v for chip.
Ok now, you can run DSD 512 and check all Regulator : 1.2v , 3.3v and tel me all you see for e-mail; quanghao168@yahoo.com.vn
thanks
Thanks!
hi!
please , you need upload the last firmware for Amanero!
thanks
Thanks!
Could you give more info about your problems with DSD256 and DSD512 ?
- More Vendors...
- Quanghao Audio Design
- DAC-END R (ES9018) full assembled board - version 2
