Michel,
Maybe you could tell us which issue of Electronics World the article will be in?
A folded cascode models as a single stage and adding a follower you have a two stage amplifier, close to a straight wire with gain, I suppose.
Nelson Pass, I believe, has used this approach in some of his designs.
Jam
Jam
X?
This is interesting, however -- is this not exactly what the NP X input stage does?
http://www.passlabs.com/pdf/susy.pdf (or better still original patent at http://www.delphion.com/cgi-bin/viewpat.cmd/US05376899__?OUT_FORMAT=pdf&MODE=fstv)
I am not quite sure what a transimpedance stage is. Perhaps a short explanation on this might be in order since my Horrowitz and Hill is not avaible for now.
Petter
Petter
- Current-mirrored Folded-cascode
