Actually Sanken is distributed by Allegro http://www.allegromicro.com/en/
But who distribute the sanken to germany where privat customer can buy this. The two in the list of allegro that distribute to germany only for Companys and has no sanken transis in his product list.
Dirk
Hi small_boy
In Germany don’t know.
But I strongly recommend you http://www.profusionplc.com/pro/gex/manuftable1?imanuf=sanken in UK.
OK, have mail from ISCSemi !
The 2SC2922 with scratch are realy from ISCSemi. OK, less one problem.
The service of ISCSemi is very good and fast. I was real astonished.
Miss Lynn from ISC has send me per mail the Datasheets for the 1216 and 2922. because probs with Homepage of ISC.
When i look in the datasheet i mean that the data are same as the data from Sanken´s 2S. Or not ?
Datasheet of 2922 :
and for 1216 as pdf attached.
Big different between Sanken and ISC ?
Dirk
Datasheet of 2922 :
Dirk
Have a look at this tread:
http://www.diyaudio.com/forums/showthread.php?postid=1415991#post1415991
Tarzan
Tarzan
Hello Small Boy (again) and all others,
Got the AN scanned and convert each page (8) in to a pdf file.
Sorry to tell you they are HUGE in size.
An RAR file with all 8 of them is 22MB.
Each file in turn about 4.5 MB.
Contact me direct so that I can send them to you.
It needs however a seperate 300V psu.
This instrument could be a very interesting project.
It will surely have it's use with all the counterfeit power transistors around that can blow up your expensive repair or project.
Tarzan
Tarzan
Here are the links for download:
Page 1 to 8
http://www.yuntaa.com/FileManager/Download.aspx?ContentID=45790F7E83E653E4E040A8C003022DED
http://www.yuntaa.com/FileManager/Download.aspx?ContentID=45791404ACE0D1BFE040A8C003022DEB
http://www.yuntaa.com/FileManager/Download.aspx?ContentID=457949ACAB92DFA4E040A8C00302311F
http://www.yuntaa.com/FileManager/Download.aspx?ContentID=45790F7E83E853E4E040A8C003022DED
http://www.yuntaa.com/FileManager/Download.aspx?ContentID=4579242F3D9921C2E040A8C003022F96
http://www.yuntaa.com/FileManager/Download.aspx?ContentID=45791404ACE5D1BFE040A8C003022DEB
http://www.yuntaa.com/FileManager/Download.aspx?ContentID=457941531292B9C0E040A8C0030230C4
http://www.yuntaa.com/FileManager/Download.aspx?ContentID=45790F7E83E753E4E040A8C003022DED
Sorry for the mess.
Page 1 to 8
Sorry for the mess.
It will surely have it's use with all the counterfeit power transistors around ............
Could I suggest you start a new thread for the construction of the tester.
I, for one, would be interested.
Andy
Thx Tarzan !
i find , thats a good idea
Yep, I think it is.
I had a quick look on ebay to find out if most of the components mentioned in the 30+ year old document are available.
Well the mercury wetted relay is available, as is the pulse generator.
The other components like the semicons can be sustituted by others.
Some parts as the psu can be simplified by a LM317 etc...
But I start a new tread this evening.
Let's declare war to the counterfeit transistors...
Tarzan
Tarzan
Hi all,
Here is the new tread:
http://www.diyaudio.com/forums/showthread.php?postid=1422436#post1422436
Thanks for the support.
Tarzan
Tarzan
Does anybody know who is manufacture of this transistors?I think that 2N5551 is manufactured by ON but who made second one?
Here is my super fake on the right, genuine on the left. The die of the genuine is closer to 6mm x 6mm. I spent much time smashing the genuine. For the fake, or super fake, it was a matter of an extremely weak pliers force:
Notice how this super fake has numbers on it in the lower small circles, notice how the mold was easily removed. I also noticed that the mold in the genuine is so much stronger and is of much higher density, contrary to the fake ones:
And those were the so much fake, their sound sucks, and no numbers in the small lower circles:
These are excellent photos, rarely found on the net, I don't recall I came across very close and clean photos of genuine and fake. I can also provide excellent photos for genuine 2SA1943 and 2SC3281. If any one is interested let me know.
- ### Counterfeit transistors
