Hi again,
here is the updated version. I've added rounded traces, power traces are on both side of the board.
And a 3D rendered picture of the board
Any comments? I think this is done now.
Thx,
Kari
Thx,
Kari
I have actually done that already. That's why i had to order D,Se,G and S the way they are on the AX board. My inital plan was to make a A3 with these boards but they should do nice on a AX too.
I should receive my first batch of 30 driverboards on Monday or Tuesday.
Here's a pic of the layout:
Thermals
Hi Aurora,
My thermal problem is not a visual on sceen effect, i know what you mean. I studied the help files but i couldn't find the solution.
When i look at the last .png of Kari's design you see the cross connection from a path to the polygoon.So it's possible with Eagle.
Hi Kari,
How did you do that ?
B.t.w. that 3d picture is great !!!
Is that special 3d software ?
Best regards,
Johan.
Hi Aurora,
Hi Kari,
Best regards,
Johan.
Joho:
I have actually done nothing settingwise to Eagle to get those thermals. I do run version 4.13 if that has anything to do with it.
You can find the 3D software for Eagle here http://web2.callisto.twam.info/eng/index.php?page1=eagle3d
I'll check on howto setup a Wiki page for the groupbuy tomorrow (Sunday).
I'll also post scans of the driver pcbs as soon as i get them.
Thx to everyone for their input
/Kari
/Kari
The group buy is up @ http://www.diyaudio.com/forums/showthread.php?s=&threadid=41943
Signup here: http://www.diyaudio.com/wiki/index.php?page=AX
/Kari
/Kari
OK, I'm tempted to jump in on this as well but I have a really easy question.
How many Driver PCBs do I need for 2 channels? I see a lot of 2 main, and 4 driver orders but 4 driver orders is only 12 fets but the schematic calls out 8 fets per channel or 16 fets. So I would think you need 6 driver PCBs (3 fets each) and 2 main boards.
Or is the picture wrong and the Drivers PCBs have the 4 fets not 3?
Thanks,
Howie
Thanks,
Howie
Hi Kari
I have been comparing KK's schematic with Greys original schematic. Mostly just to see where they defer from each other, but also to get a better understanding of the circuit. I have noticed that Kristian have omitted the zeners from the input. Do you know of any pro's and con's by doing that?
Also I have noticed that both Out- and Out+ is coupled to ground by either a 33ohm 3W resistor in KK's schematic or 2 parallel 62ohm resistors in Greys Schematic, but I can't find them on your board. Have I gone blind (wouldn't be the first time) or have you omitted them, and if yes then why?
Lars
Lars
Please have a look here: http://www.diyaudio.com/forums/showthread.php?postid=484995#post484995
/Kari
/Kari
- Comments on my Aleph-X layout?
