Is C65, and C24 missing also?
Well,sorry
C65,C73 is bypass capacitor for Vcc(power)
I am not found C18,C24 on schematic Metis3
The new vesion
The new vesion of the clone Goldmund Amplifier,today I re-layout with dual channel versions.
Original metis 3 circuit(#390.2)
All in one,dual chanel,very compact, using SMD components, ... compatible with heatsink have the length > 16cm(heasink in picture my layout is 19cm)
Appropriate for many types of chassis.
Happy New Year
Regards.
Happy New Year
Regards.
Very appealing PCB, it's just that I don't like this kind of output BJT assembly, it is self limiting and has good thermal spreading only in installation you've suggested. PSU part has only 3200uF per rail, this is not nearly sufficient for two pairs of outputs per channel. 32000uF sounds more adequate ...
thank for your comments.Very appealing PCB, it's just that I don't like this kind of output BJT assembly, it is self limiting and has good thermal spreading only in installation you've suggested. PSU part has only 3200uF per rail, this is not nearly sufficient for two pairs of outputs per channel. 32000uF sounds more adequate ...
Hix,this is the original circuit
I've said in the topic"The Very Best Amplifier I Have Ever Heard!!!! "
Have two ways to have great sound with Goldmund circuit(lateral mosfet output) is:
1. High current bias(200-300mA), with power supply enough clean (large capacitance>10.000uF or parallel multiple small capacitors),it raises more heat,heatsink must be large enough.Goldmund does not choose.
2. Low current bias(70-90mA), the power supply does not need too clean(for Power Amplifier stage - Output).Goldmund has chosen this option,so they just choose capacitors for the power supply is 2200uF +1000uF = 3300uF.Their heatsink is very small.
Because the small capacitance means is the impedance power supply will be greater,it raises many harmonic distortion on the load speakers, when considering the load resistor to announce the results, it is very low harmonic distortion but the reality is not so, the speaker is not the same as resistance.
Sounds great,to less expensive materials,structure machine not bulky,be durable by very low-temperature,little damage, very aesthetic,...
Regards.
P.S. BTW 2200 + 1000=3200
Ok,maybe you're right
Nice work. R25?, R2?, Not MM390.2
My opinion is the value of resistance has not influence to the quality of the amplifier.
Because impedance of ccs is very large,if connected with an resistor is also not different.
The main task of this resistor is reduce Vce NPN(made ccs) also is reduce temperature for this BJT.
I do not understand why Goldmund changed value this resistor in their circuits,
Although in theory it only should ensure that Vr = Rx4mA < 50V => R< 12.5k is ok.
Some original circuit:
Happy New Year
Regards.
Hi
I'm very interested in your project , this is ver ULC , and i like it
Can I register a set of Board .
always support you
Happy New Year .
Hi
Arcording to some friends at VNAV Portal - Trang ch? forum you and the OP live very close to each other , so just come and pick up board why have to create list..
Functions protection of the Metis3 is:Analogue output protection? On a separate board?
-Turn on relay slower a few seconds when power on
-Turn off relay fast when power off
-Turn off relay when B+ reduce.
Not protect DC on the output amplifier,not protect when over current,...
So I remove it to direct output to speakers
Regrads,
- Clone Goldmund Amplifier
