hi andrew that is supercool with the right power supply current (which is obviously igbt smps ) it will produce around 14,000watts rms at 2ohms P=V2 / R power=voltage squared / resistance"impedance"
very great andrew congratulations again.
No. The right formula is: P=v2/2R. Which means maximum about 7kW.
Sajti
Why i can download the schematic..? Would u sent a schematic to me using email?The Labgruppen FP3400 schematics you can download form here
Categorized Schematics and Service Manuals for free download I-N
And I attached Yamaha T3n power amp with EEEngine
And maybe this has something to to with this Yamaha patent
Amplification circuit
hi there ,,,
i know i'm late about this project .....
@andrewlebon ....would you care sharing the details of those coils and toriods on the class d side of the project? I was researching on the net about those coils and toroids but haven't have any luck.......
namaste..
macweb
namaste..
macweb
Sajti
Holy freakin crap bat man that's a lot of power curious how it actually sounds with all that power compared to other lower power amplifiers ?
Lawrence
hi all
i wonder between class d, ab , h ,hd or td what are advantages and which one is clearer and cost effective than the rest .
if the amp is used for pa
below images class td lab gruppen in fp 10,000 uses 12outputs per channel and is very stable at 2ohms wattage at 2 ohms is 2500watts
diysmps
diysmps
https://www.facebook.com/andrew.lebon.73 you can download files from here
what software do I use to open Yama D7000W.zip
PCB is in Sprint-Layout 5
And the diagram in S-Plan 7.0
hi please post the pcb pdf files
- Class-AB meets Class-D: Yamaha's EEEngine Topology - where are this Diy Projects?
