Chip Amp Photo Gallery
hey pelayostyle
do you still have a parts list minus the enclosure laying around, I would be great to just have a shopping list and buy everything at once besides the tranny and the enclosure. You have all of this XLRs and Power Female plugs and the amps and control. Plus my enclosure is almost identical to yours, I would really love to built almost a replica of your amp.
Thanks, Lincoln
Although I wish this was my amp, it belongs to nycavsr2000
Well... now that I finished my amp i guess i should throw some pictures in here.
It's a "chipamps.com" lm3886 stereo kit,an 18v torroid and an alps 20k pot. I made the enclosure from an 8" section of 5x5" aluminium square extrusion 1/4" thick with solid walnut end caps.
I am very pleased with how this kit went together and how good the amp sounds.
Thanks to everyone on this forum for the inspiration.
Graham
Thanks guys.
It is definitely a solid enclosure, I wouldn't want to drop it on my toe. But it does make a great heat sink.
The other surprising outcome of using it was that my wife remarked how she liked the sleekness and look of it. Happy wife, happy life and I don't have to hide it from view.
Gainclone case ( with class D amps )
Here is my GainClone case, built using a couple of tin candy cans.
More information on “The reverse GainClone” thread ( http://www.diyaudio.com/forums/chip-amps/297538-my-reverse-gainclone-idea-gaincard-like-case.html ) in Chip Amp Forum.
Ciao.
Luca
LM3886 Mono Amplifier
For a long time I really wanted to have small chipamp built around LM3886. I had few Hammond 1455T1601 enclosures laying around and decided to make mono amplifiers. Cases are 165mm wide, 160mm deep and 46.5mm high. It was quite challenging to fit power supply and amplifier into such small enclosure.
I designed amplifier PCB which measures 40mm x 25mm and that is only slightly bigger than 2€ coin. It doesn't have big filtering capacitors, but I can fit 680uF 35V in there. Since classic power supply (toroid and filter caps or similar) would be too big to fit in such small enclosure I was searching for PCB mountable SMPS. I was using SMPS, from Meanwell, to power LM3886 before, but only bigger models. I stumbled upon IRM-60-24 which is just small enough to fit two of these into the enclosure. For heatsink I used aluminum block (40 x 40 x 100).
How it turned out see the pics!
Best Regards,
Aleš
p.s. Those two ants should see the oculist:D I wasn't able to hit those holes perfectly:(
Thanks. To be honest electronics design is my main profession and fine mechanics a secondary. However I build this completely at home as a fun project. Just in my own workshop by hand with regular hand tools and an electric hand drill + drill stand. Only for bending the heat pipes I borrowed a special bending tool from a friend. Casing did come ready made (to some extend) from Ebay.
The PCB in front is the PSU control. It is the click-on-click-off and remote power control to power it on/off from my pre-amp. It also has the inrush current limiter, dc protection and over temperature protection. With 2x 120VA transformers inrush limiting isn't strictly necessary but it avoids the switch on "humpf" and less aggressively charges the buffer caps at power on.
Heat pipes can have the habit (but not necessarily do) to degrade after 10 - 20 years. So I added thermal cut-off's for safety.
Power is 80W rms_sine into 4 ohms and 55W into 8 ohms before clipping. More than sufficient for regular listening. My speakers are 6 ohms mostly.
Ah OK. Is the inrush current limiter, dc protection and over temperature protection on a custom board too?
Yes, is customised to fit in the cabinet at hand. So it's a one of. Attached the DC protection. It is an integral part of the power amp PCB. The opto controls the reset of the NE555 FF on the relay board. In case of DC it just turns off the whole amp. This way, DC protection from as much as needed amplifier boards can be simply paralleled without interference/ground loops.
Lm3886 handmade amplifier
Lm3886tf 4ohm or 8ohm at 19V an 25V
Dac lampucera with tubes
2 mores inputs selection
VU meters
