My vintage look Chip Amp
This is my new amp.
It's based on a Brian GT LM3886 Kit with some modifications.
The sound is very good to my ears, this the best power amp that I ever had.
The enclosure is mainly made of wood.
Despite the holes I have made under and over the heatsinks, the temperature grows rather rapidly in the enclosure. I will have to change the back plate layout so that I can have the heatsinks outside.
Some Technical details are available here :
http://www.diyaudio.com/forums/chip-amps/187908-lack-bass-lm3886-4.html
Bye.
This is my new amp.
Bye.
Thank You for your comments and your help.
@deadhead : pm sent.
Many thanks for the PM.
You should consider to add holes above and below the transformers, too.
I know I've already posted a pic of my LM4780 chip amp and power supply, but I couldn't resist posting a couple of pics of my DAC/Pre amp I've just finished coupled with my LM4780 amp:
The DAC/Pre amp with IR reciver, motorized pot controlling a Lightspeed Attenuator and channel selector/mute on the left knob using a rotary encoder. All controlled by a PIC16F690 microprocessor.
Fits in very nicely with my original PSU and chipamp
Simply Beautiful !!
still allot to do......
BUF634 headphone amplifier
My headphone amplifier based on BUF634T, the PCB is designed as dual mono but I am using it as stereo. I the near future I will replace this LM317/337 regulator with tracking preregulator based on Linear technology LT's, that is why the wiring isn't done so well.
For the casing I have used old PCBs and two aluminum profiles from other casing. RCAs and headphone jack are from Neutrik, volume button and rhodium IEC are from ebay. I really like it visualy and sonicaly, sound is very neutral with lots of dynamics and really goes well with mine HD598.
Best Regards,
Ales
Best Regards,
Ales
Wow - very creative case construction. I really like it!...
- Chip Amps
- Chip Amp Photo Gallery
