Here are the specs on the 6550 with the type of amp I want to build and a couple of applications. The curves for the tube I found online is attached.
Thank You,
Sal
NJ7P Tube Database Search
6550
Power Pentode
Base & Bulb ( RCA RC-29 - 1975)
EIA Base 7S
Application
Glass octal type used in the output stages of high-fidelity audio amplifiers. Requires octal socket.
Mechanical Data
Pentode
Input ......................................... 14 pf
Output ........................................ 12 pf
Grid to Plate ................................. 0.85 pf
Maximum Ratings (Design Center Values)
Pentode
Plate Voltage ................................. 600 V
Grid No. 2 Voltage ............................ 400 V
Plate Dissipation ............................. 35 W
Characteristics and Typical Operation
Push Pull Class A Amplifier
Plate Voltage ................................. 400 V
Grid No. 2 Voltage ............................ 275 V
Grid No. 1 Voltage ............................ -25 V
Plate Current (Zero Signal) ................... 180 mA
Plate Current (Maximum Signal) ................ 270 mA
Grid No. 2 Current (Zero Signal) .............. 9 mA
Grid No. 2 Current (Maximum Signal) ........... 44 mA
Load Resistance ............................... 3500 ?
Power Output (approx) ......................... 55 W
Grid No. 2 Voltage ............................ 300 V
Grid No. 1 Voltage Derived from
Cathode Bias Resistor ....................... 140 ?
Plate Current (Zero Signal) ................... 166 mA
Plate Current (Maximum Signal) ................ 190 mA
Grid No. 2 Current (Zero Signal) .............. 7.5 mA
Grid No. 2 Current (Maximum Signal) ........... 39 mA
Load Resistance ............................... 4500 ?
Power Output (approx) ......................... 41 W
Push Pull Class A Amplifier (Triode Connected)
Plate Voltage ................................. 450 V
Grid No. 2 Voltage ............................ 450 V
Grid No. 1 Voltage ............................ -46 V
Plate Current (Zero Signal) ................... 150 mA
Plate Current (Maximum Signal) ................ 220 mA
Load Resistance ............................... 4000 ?
Power Output (approx) ......................... 28 W
Total Harmonic Distortion ..................... 2.5 %
Push Pull Class AB1 Amplifier
Grid No. 1 Voltage ............................ -23 V
Peak Grid No. 1 Voltage........................ 17 V
Total Harmonic Distortion ..................... 3 %
Thank You,
Sal
6550
Power Pentode
EIA Base 7S
Application
Mechanical Data
Pentode
Pentode
Olá BSGD
You can have a look at the work done by Ricardo, here is a picture of one of his amps. http://www.diyaudio.com/forums/showthread.php?postid=1185789#post1185789
They fit your need for power, seem to perform quite well, reliable and the stuff. But they will cost you somewhat more than a cheap chinese though. Still cheaper than an Audiopax, I imagine...
Good luck in tubeland, Erik
I am a brazilian, and know Ricardo from a yahoo discussiongroup called justtubes.
Richard Ellis said:Bernardo:
Hi........Just down south of you here in Argentina, I am still trying to find a transformer manufacturer in country that will make a 'special order' for me...I have designed an 813 Single ended amp but the transformers would be imported....as my wife (Argentinian born) points out to me, the importing of said transformers will drive the price way out of reason.
That said, when we came here we brought our appliances which were 220VAC but the distribution was different requiring a large transformer for our clothes dryer. The KEY was this transformer was a custom made 220VAC-220VAC isolation type with a center tap on the secondary. This transformer is Appx 200 mm high, 300mm wide,300mm deep...at 20? Kilos'.
It was 'made' for appx. 1200 Pesos. This monster is priced just fine considering the Peso to dollar conversion rate!
This great pricing is what got me to consider building tube amps in the first place. Look up www.kaizenelectronica.com.ar they won't respond to my E-mails....perhaps we can work together to find suitable LOCAL manufacturers.
_______________________________________Rick...........
Well I know some guys here in Brazil that can make custom winded transformers. The company is called "PULSAR" and they really do a great job.
Unfortunately, as you know, custom duties in latin america are ridiculously high, so we often cannot go on with our projects, since we cannot get the parts. It would be great if we could find a way to get this parts somewhere at an acceptable price.
Andy Bartha said:Bernardo,
Talk to Eduardo at Audio Pax. He builds excellent tube amps and he is in Brazil. His web site is www.audiopax.com. He should be able to help you out.
Thank you very much. I'll contact him asap and post back any info.
Once again thank you. Great news.
ErikdeBest said:Olá BSGD
Thank you very much Erik, I just sent Ricardo an e-mail.
BTW, do you know Ricardo's e-mail? Thanks.
bsgd said:
Muito Obrigado!
Do you have any experiences with this amp? It looks good to me
No experience, and I would not buy it, I want a bit more quality...
This look better:
http://cgi.ebay.com/KT88-TUBE-integ...oryZ3280QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/Music-Angel-KT8...oryZ3280QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/YAQIN-MC-10L-Pu...oryZ3280QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Wavebourn said:I am going to design an amp that uses 12L6 tube as a triode and a transistor from a computer power supply.
There will be triode-pentode amp where pentode part is represented by a transistor.
There will be a 5532 opamps used that are easy to obtain.
Can 25L6 be used?
Thanks!!
pchw said:
Can 25L6 be used?
Thanks!!
Yes. I wanted to power it's filament and oPmp from the some source
Excellent, I have quite a few of these and don't know what to do with them. I am watching this thread closely from about 20 miles down southWavebourn said:
Sorry Fred, not today: I'm currently busy with my console, there have to be a concert tonight in my house. Diego Jameau is coming from Sebastopol; he is a dancer, composer, plays multiple instruments; tonight he is going to sing and play a guitar. I'm not sure if enough of guests will come to cover his fuel (suggested donations are $15), so probably he'll not come if enough of people don't RSVP, but anyway I have to prepare my equipment
(I'll post a picture of a hedgehog that's a strip from console, 2 channels). I decided to put my "Be-El-Countoiur" in this couple of channels (I did that a long time ago, when our bass guitarist liked to scream when wanted to sing aloud). And Cadmium was not restricted yet, so some more complex solutions have to be implemented to satisfy RoHS regulations...
pchw said:Hi Anatoliy,
I didn't mean to see more today or any particular date We all have other obligation that must be fulfilled first Only post the bits and pieces when you have free cycle. I hope the concert will be successful!!!
Ok Fred, I'm ready to continue the project. I'll better start a new thread to distinguish my new design from current Chinese production.
Ditto, and I was about to suggest to start a new thread as wellcrispycircuit said:I'm very interested and would expect this to be a very popular project. So get started and post at your own rate. Your time is greatly appreciated......
Ok, let me draw some sketch calculating on a napkin, bring some transformers from attic, breadboard and tweak, then I'll start the thread.
I think a "voltage" shoulder will contain tubes only, while a "current" shoulder will be made of a transistor and an opamp. However, the latest will develop some phase shifts on highs, but since it's output dynamic resistance will be high I don't expect it to be a big deal at all.
For an average current a triode shoulder will be a "leading" one, i.e. a current shoulder's idle current will be determined by a voltage drop in cathode of a triode one.
bsgd said:Hi all!
This is my first post here. Few weeks ago I got a k-12m kit and I love it... only problem is that its pretty low on power.
So I was thinking of getting a relatively cheap chinese tube amp, and I'm looking for recomendations. I'm in Brazil, so getting a used Dyna or something is not a good option, since custom duties here are very, very high (96%).
So, can anyone recommend me a good chinese tube amp and where can I order it??
Thank you very much!
Bernardo.
Bernado, there's been a lot of off-topic discussion, so but I'm replying to your original post. If you think the K-12M kit is low on power, you might be better off investing your money in some high efficiency speakers. I picked up a pair of Cerwin Vega VS-150 speakers off of craigslist locally for $200... they're rated efficiency is 102dB... a potato could drive these to insane volume levels. They're huge though!!
But if you really want to upgrade to a quality Chinese amplifier, I really recommend the Yaqin MC-100B amplifier. I bought it off of eBay from Canadian Hi Fi Online. Every amp comes with a 1 year full replacement warranty plus a 3 year labor warranty (you just pay for parts). KT88 output tubes, 30 watts triode / 60 watts ultralinear, for $800 shipped to your door. Canadian hi fi inspects, tests, and sets the bias on each amp they sell, so no surprises.
I don't work for them or anything... I'm just a really satisfied customer.
Charles.
ebay.com/Yaqin-100B-4-x-KT88-Stereo-Tube-Integrated-Amplifier
bsgd said:Do you have any experiences with this amp? It looks good to me
You have to beware that 2 of these amps, looking the same on the outside, can have very different quality of parts & iron in them.
dave
Got proof? Pictures? Or just hearsay? I'm not trying to be a jerk here, but it really sounds like amp bashing to me.
I'm not saying the Yaqin is top of the line... but for $800 shipped to my door it's top of the line enough. You can't touch something similar made in the USA for under $2500.
Charles.
Charles.
- Tubes / Valves
- Chinese Tube Amp?
