Chinese ES9018K2M I2S DAC
Hi Drone7 - looks very interesting - are you using i2s or usb or..... and what software are you using? Thanks Adrian
Oops - I see you answered most in your earlier post - but just to clarify - you are not getting noise or glitches between tracks or on changing sample rate tracks - even on high res?
Nope, no noises,clicks,pops or otherwise. Plays smoothly when moving from 24/96 to DSD to 16/44...:)
Tried with PiB, Pi2 and Pi3B and Moode Beta8 and/or HP t620 thin-client with Daphile or Snakeoil OS using LMS. All work fine.
Using usb to i2s.
No idea as to how it would perform using i2s direct as there are no drivers (yet?)
Would you be so kind to draw some sort of schematics?
Of the switch and connection ? Attached..
3pole 4position switch.
Position 1 connects as if jumper J2=optical spdif in,
position 2 as if jumper J3=coax spdif in,
position 3 as if jumpered both J2 & J3=i2s in,
position4 no connection so acts as mute.
It matters not which pin the black wire connects to on that side on the board header as they are all shorted to each other.
@yogilla62
Maybe on the drivers AUDIOPHONICS I-Sabre DAC ES9028Q2M Raspberry Pi
Tried that . Does not work
@freezebox
Did you try hifiberry DAC or generic I2S drivers? & Do you have another DAC to test I2S output from Pi?
Tried all those. None work.
Yes, I have several i2s dacs and they all work fine with the pi.
I have a couple of Pi and all have the i2s problem with this dac.
The usb to i2s works with this dac but so far no i2s drivers do.
I recall reading that the 9038Q2m is equivalent to two 9018k2m so drivers may be very different
Thanks for the suggestions.
I dont think its a driver problem. If the pi gives out an I2S signal to other DACs, then also here.
You can try:
1) input series resistors of 33...100 ohm for each I2S line.
2) Change start up order - e.g. my 9028 needs first the I2S signal then the power for the DAC chip.
3) reduce wire length and/or use shielded I2S wires
good luck!
What do you think of this board?
I've no experience with the Amanero sorry.
The two boards I referenced both have a couple of things that I would find useful...
1) option to power the board from a separate supply instead of via the usb cable.
2) file indicator leds... the Diyinhk's add on board is quite comprehensive, the 'sky song' board I'm still figuring out what the F/0/1/2/3 leds refer to.
Both boards have pcm/dsd indicators.
The sky song board xmos is xu208 same as your second board.
The Diyinhk is latest xmos 216 (said to be equivalent to 2 xu208's)
Sometimes you just have to make a decision and run with it... :)
Thought id add to this as i'm on the forum and just spent a while making this.
I got this board last year, as is, tested with a dir9001 gave it a listen and was super disappointed. you can tell when there is scope for improvement and this was too far in the wrong direction. i threw it in the big box of boards and forgot about it. two months a ago i decided to build a 1 box music streamer/DAC with an Rpi this DAC (to prove concept) to listen to DSD and to replace my squeezebox + dac. This is now my main DAC.
pics attached.
enclosure: old network hub thing, used the SMPS within
110v AC 80VA toroid, 180vdc CRC
x2 9V 30VA toroid 317 - 1117, each 317 tapped direct to 9018 board with traces cut to separate
SMPS: +5.25v to Rpi3, +12.6v to heaters
RPI3 running max2play, music stored on network
xmos u8 USB
ES9018K2M (old cheap $9 one not the one with bigger board or fancy black one), literally using 9 components on the board.
SRPP output direct from DAC pins
6N6P valves
clarity cap PP output caps
Ive used only what it needed to keep cost down and i'm amazed at how good it sounds.
