CDM9 Pro.....where are they....?
.....it's working - i repaired it.....:D
it was the lasers thin foil cable that was damaged, one of the copper leads was cut in two.
i was really nervous that the krell was dead.....and now it's playing better than ever - i replaced all the caps on the controller/sevo board with oscons.
next up is black gates nx arround dacs and I/V opa's.....
CDM9 Pro
I have Theta Data BAsic II transport. Sadly, the gear that spins so that the drawer can open/close is broken. How can I get another gear? Theta has some but they are not only costly but are not original and thus was told by Theta that my drawer will not open/close smoothly.
Thanks in advance,
Gary
There is hope.....
The pro and 9/44 use the same tray gear. Philips used the cdm9 on the CD951 and CD931, choose which one of the two you would like to "own" and call your local Philips repair agent and ask for part number 4822-522-33192.
I ordered this way and got them here in South Africa (took 6 weeks) for about USD4.00 each. I believe this item comes in and out of stock at Philips these days but I enquired with a Dutch parts reseller about 8 weeks ago and there was stock. They wanted to charge me a huge handling fee, 3 times the price of the gear. The repair agent did not.
It is said that the grease used on the gear and tray is what makes the plastic brittle, so before you put in a new gear clean the tray thoroughly and use something non agressive like silicon grease. I used a little Wynflon. Teflon based stuff from Wynns.
The job takes 20 - 30 minutes, you will need a torx screwdriver set to remove the control pcb from the mechanism.
Good luck!!!!!
CDM-9 PRO uses a brushless motor, all other CDM-9 versions not. Maybe for this reason models with it quit rare.
according vasiltech there are this models with CDM9pro:
AUDIOLAB 8000CDM
AUDIOMECA MEPHISTO
BARCLAY DIGITAL F1
BARCLAY DIGITAL X-1 CD
BURMESTER 939+963+969+979
DUSON CD100
EMT 982 BARCO PROFESSIONAL
Forsell Air Reference Air Bearing
GOLDMUND MIMESIS 36 CD
GOLDMUND MIMESIS 39 CD
GOLDMUND VSR CD
INKEL TEMA CD-1
JADIS JD-1
KRELL KPS 20i
MARANTZ CD-23
MERACUS IMAGO
MICROMEGA DUO.CD. (partly CDM-3)
MICROMEGA DUO.CD2.1
MICROMEGA TRIO.3CD.
MISSION-Cyrus Discmaster
NAIM AUDIO CD1/CDI (partly CDM-4/27
POLYFUSION AUDIO MODEL 920
PS AUDIO LAMBDA
PS AUDIO LAMBDA TWO
RESTEK RADIANT (ver. 3)
ROTEL RCD-990
ROTEL RHCD-10
SHERWOOD CD-1 TEMA
SPHINX PROJECT NINE MK2
SUGDEN AU51 PRO
SUGDEN PDT-10
SUGDEN SDT-1SE (SDT-1PRO)
T+A CD1400AC
T+A CD2000AC MKII
T+A CM3000AC
T+A CM3000R
THETA DATA BASIC
THETA DATA BASIC II
VIMAK DT-1000
The brushless motor is never the issue. If you want to find a low mileage laser buy a kodak pcd865. I picked one up, nos, unopened on ebay for £100. Ten minutes later I'd gutted the cd mech, vac bagged it and now I have a spare should my audiolab cdm transport ever die.
not the brushless motor itself, but the ribbon connector, if destroy.
Maybe this is a good replacement
https://www.ebay.de/itm/174698464039?hash=item28acd70327:g:LrIAAOSwObdgphwb
or repair according this descriptions
https://www.diyaudio.com/community/threads/any-way-to-fix-the-ribbon-cable.49858/
