djQUAN said:those amps in the tunpo site look worryingly similar to high end amps like Focal. the other sites have ampsthat have the exterior looks similar to a lot of branded amps. no surprise there.
Oh you mean like the ARC2075SE? Looks like something "hi end" ARC Audio carries. Whoops! To enlarge an image, just left click and drag the mouse to the top of your address bar (in IE).
http://www.tunpohk.com/cp_detail.php?id=927&nowmenuid=2005&cpath=0011:0230:&catid=11
http://www.tunpohk.com/cp_detail.php?id=919&nowmenuid=2005&cpath=0011:0230:&catid=11
http://www.tunpohk.com/cp_detail.php?id=926&nowmenuid=2005&cpath=0011:0230:&catid=11
But, I digress.
djQUAN said:that's weird.....my post #42 is supposed to be my reply to your post #43.
I screwed up and double posted then deleted the first one. Heh.
Hmmm. I thought the Arc stuff was made by ubuy taiwan.
http://www.ubuy.com.tw/Product/
So who makes it and who clones it?
CBRworm said:Hmmm. I thought the Arc stuff was made by ubuy taiwan.
It's not made by UBUY, but UBUY is a distributor of ARC with house brands of its own. It says so right on their page. You know that Best Buy's house brand is called Insignia - but they don't make Yamaha Receivers. Wal-Mart's house brand is Durabrand, but they don't build Sony boomboxes.
It's a marketing site. Quite apparent from their misleading article about "Regulated Power Supplies" being somehow more robust and better designed than unregulated supplies. Typical marketing drivel.
So, if you visit Nikola's website under "Friendly Links" you will see that Cerwin Vega, Arc Audio, Clarion and others are mentioned as being designed by Nikola engineering. Of course, they are all mentioned in the links above - from the same factory. I have some serious, professionally informed doubts that Nikola Engineering is actually responsible for circuit design of these amplifiers. More likely, they are purchasing agents for Clarion, Cerwin Vega and ARC Audio and play a tiny role in the actual design, if any. Feel free to prove me wrong, as I cannot definitively substantiate this other than to inspect the design from photos and recognize key similarities with other Korean/Chinese designs.
Dear Peter Babin
I would like to buy a SMPS for my car audio amp circuit. The circuit uses 1 LM3875/channel and I would like to use 4 channels (LR Front+LR Rear). Supply voltage is single +50 V. 2-3 Amps should be enough. I saw many posts in the theme, but single supply was not among them. I would pay for a ready one, if someone would be so kind to made it.
Thanks in advance
E.K.
Thanks in advance
E.K.
greetings to you perr,,,i'd like to build an smps having a +50/-50v output from 12v source,,and have a 8 power mosfets(IRFZ44N) as drive,,,do you have a design for that? a complete diagram and pcb layout like what u have post previosly?can u help me,,im badly needed to have that one,,,once again jeph here in the philippines,,,oh by the way,,im living near Boracay island,,he he
greetings,,,mr meanman1964,,,can u pls help me?jeph here in philippines...i am interested of the smps u previosly posted,a +43v with an output current of 50amps,,dated 11th september 2007,,can u pls send me a diagram and pcb layout of our design sir?thank u so much. godbless
How much interest is there in power supplies for DIY car audio amplifiers?
This was mentioned before. How many of you would be 'really' interested in a supply that could support an amplifier of ~400-500 watts?
If there is enough interest, I may be willing to build them or to provide the main components (sink, board, transformer), with detailed assembly instructions. The prices would be ~$110 for the main components and ~$160 assembled.
This is the prototype. I ran an amplifier on it and it produced ~$500 watts into a 4 ohm mono bridged load.
I am looking for a way to Power a Car Audio Amp for use in Home Application, any suggestions?
God of Thunder
- General Interest
- Car Audio
- Car Amplifier Power Supply
