Burning Amp BA-3
Ex-Moderator R.I.P.
Joined 2005
if it follows the BA-3, check the RCA chassis plugs
but could ofcourse be worse
like a cracked solder pad on your amp board
check all your board solderings using good quality magnifying glass
and a small flashlight in your other hand
expect a really scary sight :D
I am building a single chassis BA-3 now and want to use a single transformer. I have specified 600VA with 4x 0-19V secondaries. Anyone have any comments about this design? Any advantage of this over just 2x 0-19V secondaries at 600VA?
The BA-3 doesn't need a big transformer - I think I'm using a 50VA Antek.
I'm guessing you're adding BA-1 or BA-2 power stages and the big trafo is for them? If so the answer to the power supply size is to be found in the articles and the discussions.
tim
