That's why I've made the point several times that it needs to be a cable which is agreed (by the test subject) to have a long break-in time.
All this sounds already like a sequel to Alfred Jarry's "Gestes et opinions du docteur Faustroll, pataphysicien".
Edmond, behave will you?
Seriously, I'm fine with you going after those whom makes extraordinary claims, and won't step up to the plate and prove their claims, BUT Andre actually has taken the challenge, and that deserves respect.
Magura
Don't worry, Andre does have my respect. His attitude is way better than.........well, you know how I mean. Please, don't confuse him with that other guy.
C. E.
and has a fifty-fifty chance at a correct guess. Hardly valuable.Eh?
The only difference is that the cable will either be burned in or it won't.
A burned in cable won't look any different, feel any different, smell any different, taste any different, or measure any different.
Can't hear you. The Doppler shift from your retreat dropped your vocals to the infrasonic range.
Not to fear; a properly burned-in chunk of copper will reveal the subtle details of his infrasonic vocals with a clarity you have to hear to believe.
just don't ask me to back that up
Statistics, lad. What are the chances of guessing right 10 times, with an independent 50/50 each time?
Guys, no offense, but I will not take into account input from those that are trying to derail the train. I and a few others agree to put time of our own into this test so please, whatever your views, at least respect that we're trying.
I have absolutely no bias on the issue here, and in fact, besides satisfying my curiousity, no other objective.
I will setup a wiki for the test, link will follow shortly.
The test will have two parts, the second part conditional on the first. We will send Andre only two cables first, one classified as burned-in, and the other as not burned-in. If he can tell the difference to his satisfaction, then we can proceed to part 2, where the test will involved more cables and they will not classified.
statistics, lad. What are the chances of guessing right 10 times, with an independent 50/50 each time?
0.01%
You have a 50/50 chance of a correct guess in ANY A/B type test.
Did you happen to miss the part that the first trial will involve TEN cables?
se
If JC is good enough to agree to a test like you are proposing, then it should be fairly straightfoward to come up with a simple method that all sides can agree on... and leave it that. Don't keep moving the goal posts or coming with weird ways of implementing it all.
If John (or anyone else) can pick out the cables and the result is statistically valid then you all have more to talk about...
It's a fantastic opportunity... for all involved... and those that just find the subject interesting.
Humour is a 2-way street ikoflexer, hide the account info and fly double-blind.Guys, no offense, but I will not take into account input from those that are trying to derail the train.
..then it should be fairly straightfoward to come up with a simple method that all sides can agree on...
We have done. Read back a few posts. Mostly SY's idea, and it's a good one.
Also remember, if the Listener gets it 100% wrong, that's also significant.
In other words, it does not matter if he incorrectly identifies the cable as new or bunt-in. As long as he correctly separates the 2 groups. That's all.
What about the labeling? Numbers like 4, 13 and rows of sixes have cultural connotations best avoided.
Use letters. They are only offensive when arranged so.
Seems to me that the 'single crystal' cables take longer (silver even more) to burn in, they are expensive however.
I would prefer two cables, A and B, without knowing which set is burned in, I will tell if I can hear a difference, if so, which set are burned in. You can tell afterwards whether it is correct.
Hi Andre, first let me say that I speak for many here, and we appreciate your willingness to test this. Please look at it as fun, not a life and death. There are so many more important things in life that we should take seriously. I know it's difficult, but I would like to also encourage you to not listen to those who so easily want to insult anyone simply because of different views or how we express them.
Now about your preference of a one shot test of two cables. Even a positive result can be refuted by those who are against. A sample of one is not significant. Then we put all this effort and we gained nothing. Please think about it. I am about to finish a wiki page in which the details are better described and hopefully you will find that acceptable.
- General Interest
- Everything Else
- Burn In speakercable
