Building V-2
So Hi everyone,
I have not been here for quite some time but have got the bug again (still no cure for the DIY Audio bug)
Along time ago I built a Spinner V-One, http://www.diyaudio.com/forums/analogue-source/12799-my-table-project.html?highlight=gazzafloyd I was reasonible please with the look and sound of the spinner but have move to a new Home and after a long time between drinks have been playing the black stuff once again and loving it. So I have plans to do a reBuild.
I will Post Photos soon
Thanks for looking
Gaz
Tonearm
So this is the Tonearm so far,
The lower section is Bronze a plastic arm rest and if I can figure out how to make a lifter it will be mounted on this as well, then we move on to the yoke for the arm machined for a bit of Alu that I cast in the Foundry I have been playing around with. The Bearing for this caused me some problems it wasn't untill I looked closley at the cutter on the lathe that I figured out what was going on, I had a chip in it so I was turning down 1/2mm to far. It took three goes to get it right.
From there the arm will be Carbon Fibre
I will keep posting
Plinth & Platter
The Plith,
This is going to be a total rebuild for the most part made out of Black Acrylic had a local Plastic company lasercut for me, just got to polish the edge's. Photo shows with protctive covering on.
The Platter,
This is comming straight off V-one with the bearing also
THanks
Made some progress
So after a long time I have finished the rebuilt Motor Pod, inside is a Garrard motor
This means I can now move on with the arm
G
So I have had another good few hours in the work shop, love being on Leave from work.
I have joined the two part of the arm mount, the Arm is a Carbon fibre Shaft from a umbrulla the next parts I need to figure out are the Counterwieght and the Cartridge Mount. If anyone has any thoughts or ideas I would love any input
Gaz
counter weight
Hi all so more fun had, counterweight made weight cam in at 117g.
I think it will be ok middle of the weight range for tonearms the mass sit's in the same plane as the piviot point.
I decided to see how it tracks and turned it in to a Gramaphone. A small sewing needle and paper cone (sorry to any Billie Joel fans this record will never be the same)
I have uploaded a couple of vids on Flickr
needle tracking | Flickr - Photo Sharing!
Butchering Billy joel | Flickr - Photo Sharing!
Thanks for looking, and again ant thoughts welcome
Gaz
Headshell
Great Progress today.
Headshell coming on well weight comes in at 43g, Cartridge will mount to an acrylic disc that will allow for Alignment not sure what the right angle is any help on this would be great.
Gaz
more fun had
Might be my last post for a while, got to go back to work tomorrow.
So some more photos a couple of over view shots, and a couple of the headshell with a cartridge fittted
Thanks for looking as before comments and thoughts are very welcome
