Re: LRM schematics
Hi John,
Many thanks for sharing the schematic. I know we always could email you to ask the schematic but I think the schematic you just attached make this thread complete with your schematics.
Now I will start to solder the components which I have sourced here to the pcbs that you've sent to me and then find this UTOS will be more usefull than USBDI2S so I will try to make a board from UTOS schematic and to build it at the first try instead USBDI2S.
Any special consideration to use CS8416 instead using CS8414? It will be more easy to source the latter here.
Then I assume that I can use the oscillator you've sent together with the kits? Is that right?
I have one more question.
I have some op-amp based super regulator pcbs which ready to use now. I've bought them three months ago and planned to use one of them to supply the master clock instead shunt regulator. I have read from other thread in this forum that op-amp based super regulator is not to be worth in some critical circuit. What's your experience about this issue?
Thank you.
Hi John,
-ecdesigns- said:Hi ims,
The opto-couplers support sample rates up to 96 KHz (CS8416).
The CS8416 I2S outputs also run through these opto-couplers (source selection). I use a small TOSLINK receiver module for SPDIF, but design is such that a high-quality pulse transformer can be added too (coax).
The low jitter 48 MHz master clock feeds the shift register through a 22R metal film resistor. The shift register is not reset like with the previous reclocker, but the output is inverted, and fed back to the second input. This results in a rotating bit pattern, fully synchronous with the master clock.
The master clock power supply is a shunt regulator (precision band-gap reference diode), programmed at 3.85V.
Thank you.
Hi -ecdesigns-,
Thanks for your previous "compensation" tip for opamps and the AD link: extremely interesting. I am using your noise manipulation advice and it works great, as all your advices do (I have to buy some metal-film resistors, though, to optimize it).
Hi Ims,
It appears as superregs could oscillate with low ESR bypass caps downstream, so one of two option: or you don't install bypass caps near components and power from SR (at your own risk), or, preferably, use stock power supply. I recommend try first stock option.
M
Hi Ims,
M
-ecdesigns- said:Hi Telstar,
There are plenty of new mods, but I have little time to post them.
Hey John,
I see that you are very busy updating the DACs
But did you get my last email (of about one week ago)?
Ubuntu vs XP
Hi all
This seems a bit off topic BUT :
Ubuntu (studio) vs XP (pro) on a laptop ----> DAC DI8M (usb or spdif)
Ubuntu wins far out ! Why ???
And then :
Disable in device manager both 2 drivers under "battery" . ( ac driver and acpi battery manager)
Who wins now ?? In my case XP on four (4) different laptops !!
I use kernel streaming usb -foobar or spdif with a vxpocket pcmcia card on an external clock)
Pse try this out and let us now if gates or I suck.
Onno
Hi all
And then :
Onno
Re: Ubuntu vs XP
imo win works far too complicated, too many processes on mainboard inducing interferences
Re: Ubuntu vs XP
Try vista x32 with XXHighend player.
Onnosr said:
Ps try this out and let us now if gates or I suck.
Onno
An interesting article about digital sources; PC V/S transport.
http://www.positive-feedback.com/Issue22/nugent.htm
We are on the right path.
M
M
tubee said:viesta, yuck
Tubee
Peter at XXhighend is about to issue pre-production version 9u which he thinks might be "a revolution in playback of digital sources" using the Vista operating system.
Whether Peter is right or wrong, it may be worth taking an open-minded approach to borrowing a Vista PC and trialling the software.
http://www.phasure.com/index.php?topic=365.msg2379;topicseen#msg2379
Cheers
Frank
Sorry for offtopicness.
I see a lot of people in a daily basis, i can tell you for sure they have a lot of comments about vista, it is not the appropiate upgrade on xp as it should be. The moment i let win slip into the ravine here at home was the best decicion i made on pc-matter. For instance i have on an old winxp ready machine 1.8G/ 1st sdram 756mb/ 128 nvidia astonishing 3d graphical effects vista can only dream of, running on linux then ofcoarse.
tubee said:Sorry for offtopicness.
Sorry. Are we are talking at cross purposes? I am interested in researching the prospect of achieving the very highest/ultimate quality sound from a PC music server. I am not bound to any OS to achieve it.
You requirements and uses for a PC might be quite different
I understand that that machine will run sluggish under Vista, but for the best possible SQ I dont think that linux can match it with either asio or xxhe.
I do not understand why such a firm like MS can earn so much money with unsatisfying OS stuff and programs. My kids have to work at school on w2k machine, because they are forced to do so. The teacher complains why she has to update all the adobe stuff every time. Whe have entered with in a new era by now, where in a company like MS is not acepted, at least not by me and a lot of others, but we stay all on win because we have learned to "work" with it. When i started with linux i discovered again the pc can work for me.
For the sound quality: there is an other thread here, http://www.diyaudio.com/forums/showthread.php?s=&threadid=93315&highlight=
I am sure for the earlyer mentioned reasons, it should be posseble to create an audiophile linux music server pc, with outstanding results. Better then apple (readed it in Audio german mag,) I have planned that too but never came so far.
err i meant CANT
tubee said:And what do you mean with, "SQ" and "with either asio or xxhe'' ?
Sorry for the acronymes.
I mean sound quality using either asio (and kernel mode) or xxhighend player, with engine #3.
Hi xp9433,
Highest / ultimate sound quality is achieved with bit-perfect data and very low jitter. Manipulations in the digital domain are NOT required / desired for High-End applications.
There should be no significant sound differences between computer or OS, if the digital audio data is bit perfect, and jitter amplitude is very low.
About higher sample rates and bit depth:
With a given jitter amplitude (every clock has jitter), resolving higher sample rates / bit depth requires (very) low clock jitter amplitude.
Lets have a look at some examples with an ultra low jitter clock of 2ps RMS, and see what sample rate / bit depth combinations pass. I used the calculation method suggested by Kusunoki.
44.1 KHz/16 bits NOS: 1 / 44,100 / 2^16 / 2 = 173ps (OK)
44.1 KHz/16 bits at 8 * OS: 1 / (44,100 * 8) / 2^16 / 2 = 21.6ps RMS (OK)
48 KHz/16 bits at 8 * OS: 1 / (48,000 * 8) / 2^16 / 2 = 19.8ps RMS (OK)
> 44.1 KHz/19 bits at 8 * OS: 1 / (44,100 * 8) / 2^19 / 2 = 2.7ps RMS (OK)
44.1 KHz/24 bits at 8 * OS: 1 / (44,100 * 8) / 2^24 / 2 = 84.4fs or 0.084ps RMS (FAIL)
96 KHz/24 bits at 8 * OS: 1 / (96,000 * 8) / 2^24 / 2 = 38fs or 0.038ps RMS (FAIL)
96 KHz/19 bits at 8 * OS: 1 / (96,000 * 8) / 2^19 / 2 = 1.2ps RMS (FAIL)
96 KHz/18 bits at 8 * OS: 1 / (96,000 * 8) / 2^18 / 2 = 2.48ps RMS (PASS)
192 KHz/24 bits at 8 * OS: 1 / (192,000 * 8) / 2^24 / 2 = 19.4fs or 0.019ps RMS (FAIL)
192 KHz/19 bits at 8 * OS: 1 / (192,000 * 8) / 2^19 / 2 = 0.62ps RMS (FAIL)
So these examples show how difficult it is to resolve higher bit depth / sample rate. It also shows that it takes approx. 100 times lower clock jitter than the excellent Tent clocks to resolve 24 bit / 192 KHz. Then there is the problem of keeping jitter that low during distribution of the clock signal.
Both SPDIF and USB interface receivers have specified clock jitter between 75 and 200+ ps RMS. If no reclocker or slaved transport is used, this barely qualifies to drive a 16 bit 44.1 KHz NOS DAC (173ps RMS).
> The DI8M has 352.8 KHz sample rate and max. 19 bits resolution. Clock jitter needs to be below 2.7ps RMS, this can be achieved with real-world clocks and careful tuning.
-ecdesigns- said:There should be no significant sound differences between computer or OS, if the digital audio data is bit perfect, and jitter amplitude is very low.
Win os will allways be "busy" with all kind of processes on the back. They interfere with good low jitter music output imo. An install with old w98 might work, keep it bare, and install specific music only players.
Or simply ubuntu studio???
This post is such a great source of idea
I still work with my single CS8414/1541A/SAA7220 + D1 DAC to learn.
I implemented the DEM Clock. I understood that the attenuator (680/180) was here to give 1 Vrms pp. I tried to remove it and let only the 470 pF caps... This has effect on sound mainly louder bass and so more bodied sound. So the question was why 1 VRms should be used ?
I know fit a DIR9001 and is planning to use the last LRM as described here too. With the SAA7220, i will have BCK à 5.6448 MHz which is not at least a multiple of 48 Mhz... To keep the same ratio (x17) will I have to use some 96 Mhz Xo ?
I have published now the my new DAC better than any TDA1541
http://www.audiodesignguide.com/DacEnd/index.html
- Digital Line Level
- Building the ultimate NOS DAC using TDA1541A
