1- Remove Legato. Connect direct to amp or preamp
2- Reinstall original firmware chip (this will give you full volume, but can reduce the volume in the computer if you are using USB output - or else use a preamp)
Thanks a lot glt
I reinstall the original firmware chip, by pass the FIFO, connect the WaveIO directly the BIII, luckily the BIII lock for a few seconds and have music output. Although only a few seconds, at least give me some light that the BIII and Legato are not dead. There is poor contact at the I2S path. I don't know whether it is due to the U.FL sockets or cables.
Will carefully identify what is the problem. Still afraid of killing another BIII.
Thanks a lot glt
Nice to hear. Maybe you killed the Arduino?
You can also try using the BIII without the firmware chip. The DAC will start will default values in all the registers.
I have no problem on converting the bitmap to RAW and loaded it into the SD, compiled without error but can't display the bitmap. don't know whether there is problem on converting the file. Can I have your RAW file for testing?
Bigpandahk
Sorry for the delay in getting back to you I will send a RAW file now.
Are your file names less than 8 characters?
Hi glt
I didn't kill the Arduino
Finally, I found all the problems and the BIII sings
I shouldn't make so many changes in one goal and was so unlucky that several faults occurred at the same time even some simple things. The final fault was related to Ian's BIII adaptor (not Ian's fault)
After I cleared the SSLV short circuit, BIII seemed function but have problem to communicate with Arduino and no sound. The I2C level converter to the Arduino may have been killed by the SSLV fault. I followed glt's suggestion and luckily had several seconds of music out from BIII. Then the I2S signal path was suspected.
I have ordered three sets of Ian's BIII adaptors and soldered them all. I replaced Ian's adaptors one by one, one had intermittent lock and no sound, the second one had lock but no sound, the third one had lock and occasionally serious distorted sound. I've checked the continuity for all U.fl sockets after soldering and how can such simple adaptor go wrong?
I measured the insulation between the signal pins and GND, they are between 6x ohm to several Megaohm. Passive components should not have such low insulation. I desoldered all the components and measured them - PCB, u.fl and 20 pins socket, all the insulation are perfect (infinity).
The only reason may be I put too much solder and caused the short circuit. I re-soldered the adaptor with much less solder and put it back to the BIII. The BIII sings
Bigpandahk
Thanks DQ828
I saw your warning and kept the file names less than 4 characters
I'm relieved, I'd probably have given up in frustration, well done.
Without you guys' support, I probably have given up, thanks.
This incident push my project to dual mono, and will spend much more money and time
Hi glt
Congratulations!
Ian
Congratulations!
Ian
Thanks Ian
As I am forced to build dual Mono, When will your new clock board available
there is a silver lining to every cloud
Hi DQ828
I run the tinyFAT demo and got "xxx.RAW" file not found. Is there any program that I can test the SD card reader?
I'm not sure, I assume you haven't put the .raw files in a folder? they need to be in the root directory.
DQ828 : you instructions are very clear, I followed them step by step including FAT16 and put all files in the root directory.
I run the "CardInfo" in SD library and got "initialization failed". It just can't detect any SD card
I have a short term memory problem I forgot about my instructions
Where is this "CardInfo" in SD library and got "initialization failed" you speak of, in your computer? It's not a Apple is it.
I assume you have included all of these libraries?
#include <UTFT.h>
#include <tinyFAT.h>
#include <UTFT_tinyFAT.h>
I believe is something hardware related, will trouble shoot in the weekend. Thanks.
- Digital Line Level
- Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLV
