Buffalo III - flexibility without compromise.
Sharing the SE outputs between a headphones and a high-impedance load (amplifier) if the way to go.
Just curious though; if I'm already using the SE outputs on the IVY board to drive a pair of speakers, would I still tap into the SE output for the headphone jack? Would this affect the output to the speakers, since the signal is being shared between two sources?
I am finishing one of these now. I need to have an LED indicating power on. I have used both a Placid and Placid BP for power supplies. Can I just tap in to the test points on the Placid for the led? That should not hurt anything right? I know it's a dumb question but I had to ask before I mess something up.
Just use a resistor from the Placid output. Typically (depending on LED), shoot for 12-15mA, so
R = .012/[Your output voltage]
As Corpius pointed out, readjust the shunt current when you are done.
That was the first thing I checked. It's not the LED's themselves it's that I have no voltage going to them. I switched to each input and none of them have power going to the LED's. I did check that there was voltage getting to the selector switch and there is 3.4v from pin 4 to ground and none anywhere else on the board. Has anyone else had this problem or is it just me?
I found the problem, loose connection on one end of the ribbon cable to the switch, and it is fixed now. I just needed to not look at it for a day and go back with fresh eyes.
Now that the leds do light up they are very dim. Almost unnoticeable really. I will change the resistor and see what happens tonight.
If I have any more problems I will start a thread in the support forum Russ. I did not think of that when I originally asked the question.
I just finished this one for a member at head-fi. It sounds amazing and I would recommend it to anyone.
